      Feb 2007
      ls1 with distributer?
      i was watching one of the muscle car shows on t.v. and they were converting the ls1 over to a normal distributer.front mount style like ford.the kit came with everything needed to convert.
      my question is does anyone know who makes this kit?i thought it was msd but i can't find anything about it online.
      also if someone did this conversion along with the carb. manifold would you still need to run a computer for anything?
      thanks for the help.
      Nov 2004
      Colorado
      GM will be making it.
      Colorado
      I think it pretty much eliminates the need for a computer, I believe it also converted it to be able to run a mechanical fuel pump up front. Check this out. My question is why? Stick with the fuel injection.
      If you must go to the dark side
      The GM part number is 88958679 they have a picture on gmpartsdirect.com
      and an article
      http://www.chevyhiperformance.com/te...ower_increase/
      68 Camaro
      LS2 6speed
      Complete Hotchkis front and rear suspension, Global west SFC, 3rd gen steering box, C5 front rear discs w/ 4th gen booster and MC. 8.5" posi rearend with 30 Spline 12 bolt axles.
      Edmonton, AB, Canada
      Hell yeah..... I'd do that on a conversion.. !! You could really confuse people then...
      Actually, Wegner Automotive Research (http://www.wegnerautomotive.com) developed the parts. They licensed them to GM.
      jp
      ​John Parsons
      Feb 2007
      Quote Originally Posted by Midnight68
      i've seen alot of articles showing you can get more power with a carb over fuel injection.my motor is a '98 so if i stayed with the f.i. i would need to get a ls6 intake and i still would need a computer and harness.then when i get it running i would need someone to do ls1 edit to tune for the cam i plan on using.then there is the fuel system.
      i figure the car will be lucky to see 100 miles a month,so i'm not worried about gas mileage.i thought it would just be alot easier to run an old school carb,distributer,fuel system and not have to worry about having someone else tune it if i ever make changes to the motor.
      San Bernardino, CA
      i like the carb idea but how the heck do you hook up an alternator or powersteering pump to that thing with the disty is the front?
