      Jun 2005
      spal temp sensor?
      First post here, great site. i 've been learking for a while.
      Just got my spal controller, Can i buy this sensor from a parts store.
      Kinda looks like a GM sensor. I wasn't sure if it was spal specific. i don't have a sensor to tap into.
      Thanks.
      Debo.
      Melbourne, FL
      I have talked to SPAL about this sensor. You can use any sensor as long as it is a "variable voltage" type sensor. Most aftermarket sensors work by varying resistance. This is how autometer sensors work. So I bought the SPAL one off ebay.
      67 Firebird Convert 455 +.060 Johnny Winters TH400 74cc KRE d-port flowed @ 310 cfm heads piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
      Honest dad that 455 on the side of the block is a serial number
      Jun 2005
      Just picked up a temp sensoe for a 92 Cav. w/3.1L . My parts guy took one look at the connection, and knew it. I'll post up if it works. Thanks.
      mount joy pa
      will the stock ls1 sensor work with the spal controller mike
      Jun 2005
      Quote Originally Posted by blackwidow
      Sure will. Check out spals site, I think you can take a look at the instructions.
      The Spal sensors are pre-configured. Otherwise, you just have to program the controller for your GM one.
      [email protected]
