Results 1 to 14 of 14
Modifying an Edelbrock Proflo EFI for sb427
Hey all, I'm new here and hoping to tap into some EFI knowledge as I don't have much. Any help would be greatly appreciated.
I have a '76 vette that I am in the process of putting a sbc 427 in (Dart Little M, scat crank/rods, AFR 210 Elim heads, 10.5:1 cr: solid roller comp cams 630/630 (with 1.6 ratio rockers) 252/258 dur @ .050 and 111 LS). I had a 383 with an Edelbrock proflo EFI system in the car for about 14 years or so and am in the process of modding it for the 427. Below is what I have done so far.
Contacted Edelbrocks efi tech line multiple times to get where I am. This is a speed density, MAP, MAT type system. I need 10" vacuum to keep it working according to Edelbrock, possibly can go down to 9" with proper tuning. 1000 cfm throttle body has a unique bolt pattern and throttle position sensor, so I can't get a different throttle body, might be able to make a stepped adapter and use a different intake, but I will use my modded intake for the time being as it is already in process.
EFI mods so far
1. 48 lb Venom high impedance injectors to replace the 28 lb injectors
2. Victor Jr. intake us being worked on now because the ports aren't tall enough to match/seal with the AFR 210 heads. They are welding a bead on each runner and then will machine and port the runners and plenum.
3. Debating on a different fuel pump. Edelbrock indicates the 3500 system pump is good for 625 hp, but someone posted that I need fuel pump flow 20%-50% greater than the injector flow? 50% would be about 566 lbs/hr.
4. Got a longer duration base chip from Edelbrock.
5. Thinking about buying the winproflo software for $139, so that I can program it on a laptop. Anyone use this before?
Will have around $1200 in mods if I get the fuel pump, so still way cheaper than a new EFI system.
Thanks for any help!
Dave
'76 Vette, working on EFI sbc 427 setup, TKo5-speed, 5 point rollbar, driveshaft loop, 6 link dragvette, offset trailing arms.
