      Adjustable rear shocks...setting, quality?
      When i purchased my 68 camaro, it was a dedicated drag car and had a pair of rear shocks that have schraeder valves for adjustment. They are both connected together by a flexible hose to a single schraeder valve in the rear where they can be adjusted. They are white but otherwise i am not able to see markings on them in terms of brand name or anything.
      I did the DSE coilover conversion on the front with the Konis and also put in a pair of their drop leafs out back. Car has a SBC with Al heads and intake and TKO 600. At the time, i left the rear shocks in place figuring it's easy enough to replace them later and my budget was a little tight.
      Anyone have any idea if this kind of adjustable shock is any good for touring? What sorts of PSIs should i be running? What recommendations are there for a replacement?
      PA.
      Those are just old school air shocks. Usually used to jack a car up (improperly) to compensate for sagging rear springs or to get that `70s "stink bug stance". They`re not a good choice for handling. You`d be much better off with true adj. dampening shocks. Konis from DSE to match your fronts would be one choice. Or you can opt for more adjustability and go for something like a set of Varishock QS1 (16 way adj.) or QS2 (dual 16 way adj.) rears shocks. You`ll immediately notice a HUGE improvement over what you have now. Mark SC&C
      Quote Originally Posted by Marcus SC&C
      Thanks Marcus! Will do, but any idea what PSI i should be at until i can get some replacements? I really don't know if i should be at 10 or 100 PSI...
