      Ron Davis radiator fan switch problem
      Hey all,
      I purchased a radiator from Ron Davis with twin fans and the wiring harnesses and relays. Install was excellent, and it works great at cooling. The problem is with my high compression motor i have quite a bit of advance in the timing and when attempting to start the car hot, with the fans pulling and the starter motor attempting to start the car, the current draw is a little much for the red top optima.
      There is a solution for this problem in the instructions from Ron Davis--an "optional cooling fan switch", which i optioned. I put a toggle switch on the dash, and ran one wire to comon ground in the cowl, and a single wire through the fire wall (used grommet) to the top of the the temp sending unit. Unfortunately, although it works to keep the fans off when starting the car, when i flip the switch up, the fans are on constantly rather than switching on/off at 185.
      The radiator works so well that in short order the coolant is down in the 150s and then i need to cycle it on/off manually, which is, of course, no fun.
      Anyone got an idea what i did wrong to get this problem?
      thanks!
