06-15-2007 #1
Need turbo big block help please.
im planning my winter project a little early. i have a 396 big block that im wanting to turbo. im going to redo the bottom end and put the compression around 8.5 or 9 to 1. i might have to go blow thru for a little while but might do that Hogans racing fuel injected manifold.
First off. Can my 67-69 casting big block 396 take the power of a turbo? and whats a good size turbo? I kinda wanna go with an 88 millimeter. im not sure what size to put on a big block. im just trying to build a wicked street car that makes ton of power on pump gas.
thanks
Jesse
1969 Camaro under construction.
1967 firebird. 6.0/t56. Ridetech stage 2. Moser 9 inch. Forgeline wheels.(SOLD)
06-16-2007 #2I was told that the early 396 blocks were cast with too little nickel. This would cause the block to be weak. This was told to me after I discoverd that my 67 396 block had a crack in the main webbing. That's why my 2nd motor was a 454
06-16-2007 #3I uesd a 454 block out of a mid 80's motor home. The guy at the machine shop seemed to think it was a sturdier block than a car application, he called it an industrial block??
Turbos, 1700.00
Hot Side, 1500.00
Cold Side, 1,000.00
Fuel System, 1,000.00
The look on the face of whomever the passenger is when the tires break loose at o say 70 mph or so........priceless
06-17-2007 #4
