Thread: TKO length vs. Muncie
06-15-2007 #1
I will be purchasing a TKO 600 from Classic within the next couple months. But in order for me to run slicks at the local track, I have to have a driveshaft safety loop installed which has to be within 6" of the front u-joint.
When I change trannys in a couple months the u-joint location will change.
Now on to the point, I know part of the TKO kit comes with a new driveshaft. I need to know what the difference in length is between the Muncie and the TKO so I can have the loop installed accordingly and not have to pay to have it moved.
Can someone please help?
Are you smellin what I'm steppin in?
http://www.fquick.com/ertoys
06-15-2007 #2The overall length of the Tremec TKO is 24.07 inches from the bellhousing face to the rear of the tail housing casting. GMJIM or Jeff will chime in to regarding the drive shaft.
