      Finksburg MD
      breakdown 3-4K...
      Guys,
      Having a problem with what I think is electrical issues.
      MSD 6AL
      MSD ready to run billet dizzy
      NGK plugs
      MDS 8.5 wires
      Initial timing at 16* / 34* total with the two light blue springs so it is all in around 2600rpm.
      Car starting fine (18* initial makes it a hard start). Good idle at 950.
      However, between 3-4k I get choppy acceleration and really flat power band. Almost feels like the rev limiter but it's a 6200 chip and is working.
      10.7:1 compression with plug gap at .040. Thinking about bumping that to .045-.050 per MSD.
      Any other ideas?
      Thanks,,,,,
      69 Mach1
      Candyapple Red with White interior
      408C stroker
      587hp@6300 / 520ftq@5000
      Tremec TKO 600
      Moser 9" with 3.9 gears and Tru-Trac
      http://www.1969stang.com/gallery/COZ-69Mach1?page=1
      Fontana, CA
      Cam specs with installed centerline please.
      Nick R.
      Finksburg MD
      Sorry... I'm going to put this in my sig. until I can get my problems fixed.
      351 Cleveland stroked to 408
      Pro Systems (4150 style) 950cfm mechanical carb 71P / 78S
      all hydraulic
      Comp Cam
      duration @ .050 240 / 244
      intake lobe lift .360 / .363
      1.7 rockers
      valve lift .622 / .627
      10.7:1 compression
      16* initial ' 34 * total timing at 2700rpm
      NGK plugs .047 gap
      MSD Pro Billet dizzy, Blaster II, MSD AL6
      69 Mach1
      408C stroker
      Tremec TKO 600
      Dec 2002
      Lost Wages, Nevada
      That sounds like a grounding issue... or your timing is coming in to fast/slow for the timing needs.
      Finksburg MD
      I was thinking a ground issue also but it does have new 8.5mm MSD wires and I was careful to not route 5 and 6 next to each other. Notorious arching can happen in a Cleveland with 5 and 6 since the firing order is 1 3 7 2 6 5 4 8. I wonder if I am arching onto the metal shaker scoop base? Easy check on that by removing it. I've also had grounding issues in the past with the negative ground to the block. Basically no start up with that issue though.
      I don't think it's timing coming in to slow - if anything a tad fast.
      69 Mach1
      408C stroker
      Tremec TKO 600
      Country Flag: Afghanistan
      Check under the MSD dizzy cap for any corrosion and clean and apply dielectric grease as needed. MSD has had issues with this. Just a thought.
