06-06-2007 #1
Starting The Transformation
- Oct 2004
- Frisco, TX
- 194
5.5 to 4.5 diameter bolt pattern?
In laymans terms can someone explain what is involved in switching from a 5.5 bolt pattern in a truck 9" rear end to the passenger 4.5 diameter bolt pattern? Thanks
Bob
06-06-2007 #2The axles will have to be redrilled on a mill with an indexing head to get them accurate. This is very improtant because if the holes are not accurate then you will have an extreme vibration. You cacn send them to Moser Engineering and they will drill them for you.
'69 RS/SS396 pro street/427/4spd/9"
http://rides.webshots.com/album/576443881hfGXxd
http://good-times.webshots.com/album/568860081GZRpyZ
06-06-2007 #3
