    Results 1 to 12 of 12
      May 2007
      California
      Best LS1 engine mounts for 67 camaro
      Looks like there are a lot of companys offering Ls1 motor mounts for a 67 camaro. However I've read many people saying they have had to cut their tunnels to make them fit due to the motor mounts not letting the motor sit back enough. What is everyones experiences with the different mounts and which are the best mounts out there that prevent any cutting of the tunnel. Thanks for your responses.
      Really only three types....BRP(engine is slightly forward), S&P (slightly back compared to BRP) and I can't remember the name of the third. Mot use the first two....
      ats and art morrison
      Dec 2002
      Lost Wages, Nevada
      Quote Originally Posted by jsconiers
      ....Most use the first two....
      Not necessarily. Those who use the other two... do it to save a couple of bucks... but those also dont understand what comes with that savings. Other modifications...
      With the ATS mounts the engine is positioned as far back and as low as possible... so that it requires NO modification to the transmission tunnel. If you are looking for the best mount without any required modification(s)... the ATS mount is the answer.
      How well does the ATS mount work with the stock steering box and Hooker or Stainless Steel Works LS1 Swap headers?
      Dave
      Dec 2002
      Lost Wages, Nevada
      The engine mounts do not effect the steering box... nor vice-versa. I dont quite get your direction with that question.
      The ATS mounts were designed with everything in the engine compartment being stock and in place. They were then used in conjunction with the design and development ATS oil pan and merge headers.
      I couldnt tell you about Hooker or Stainless works. Neither of them had a set of headers for an LSx when the ATS mounts were designed and fabricated.
      My suggestion would be to call Tyler and ask him about the fitment and use with other headers that are now on the market.
      Aug 2005
      Asheville, NC
      Assuming the mounts are purchased & not fabricated, a fair statement would be most people have used S&P mostly because they have been available for quite some time & in general have good reviews. I have these & have physically seen other use them with success. The only other alternative a few years ago were BRP mounts & these seem to have more issues.
      Released within the last year or so:
      Hooker - people say these set the engine to far back
      ATS - never heard of a complaint about these, but they are more expensive
      AutoKraft- don't know much about these but looks like they had previously inspected the ATS plates
      probably others out there, but i have had mine for 2 years so I am probably not 100% up to date.
      Dec 2002
      Lost Wages, Nevada
      FYI~
      The ATS engine mount's have been in production for 3+ years... what you have seen as of late is a much more refined product. We changed the cosmetics until we got it perfected... to Tylers vision of what it should be.
      Hookers stuff has never really fit all that great. I wouldnt expect them to to change that anytime soon.
      As for AutoKraft... all of their LSx parts look very familiar...
      using BRP
      Will ATS mounts let you run the a/c compressor and alt. in the stock locations?
      I used BRP which does set the motor forward and I was suprised the tunnel still had to be cut w/ T56. The BRP mounts bolt to the stock motor stands. The SW long tube headers work with the BRP setup, but you must go to "front steer" rack and pinion. I did the whole BRP setup with the rack and pinion. I would imagine that the headers in any other setup look much different than SW headers. Take a look at the 69 Camaro "innovator" car on yearone.com to see what BRPs setup is. I'm not recommending any one over another, it's just that one motor mount setup means other things will be different e.g. headers, steering, clearance to radiator etc. I'd be surprised if the mounts that move the motor back doesn't require the tunnel to be cut, but maybe it doesn't.
      Aug 2001
      Wilton, CA. (Sacramento)
      Quote Originally Posted by black67ls1
      The ATS mounts actually mount the engine further forward than the standard small block, but they are as far back as reasonably possible. I installed them on my Chevelle and the engine/trans is about 1.25" further forward than it was with the Dart block. But it only has about 1" to 1.25" of clearance between the passenger head and firewall, so it couldn't be located in the same place as a standard small block without building a new firewall.
      The difference seems to be that the LS engines have the rear of the passenger head pretty much equal to the bellhousing flange, whereas the old small block had over an inch of room there ( the block bellhousing pad extended past the back of the head instead of being flush with it like the LS).
      My ATS pan and mounts fit perfect. I do not think the a/c compressor will clear the stock subframe unless you do a custom mount like Mark Stielow. I believe Tyler has this piece in the works.
      Jody
      Aug 2006
      shreveport,la
      I Had Some S&p That I Used To Make My Own And They Work Just Fine, The Motor Set's Good And The Trans Fit's With Plenty Of Room For The Tran's. I Used The Hooker Headers And I Had To Dent Them In At The Gear Box And At The Ptiman Arm, But You Cant Tell Unless You Really Look For It. Mine Turned Out Very Good
      Bedford TX
      Quote Originally Posted by jbirdcamaro
      Got any pics of your install?
      Justin, 68 Camaro Update:5 speed is in and neighbors are pissed!
