      Feb 2006
      Norway
      Corvette fuel filter/regulator
      I'm using a 99-up Corvette fuel filter/regulator on my 2001 F-body LS1 (in a 79 Cutlass Cruiser)
      Getting ready to start it up but want to be sure...
      Which is the feed, and which is the return on the "fueltank side" of the filter?
      Centre,Al
      The small hose is the return, or the on off center,,
      May 2002
      Northern California
      Quote Originally Posted by 69c4x11
      Just remember with all filters. larger hose is inlet/outlet. smaller hose is return.
      In the case of the Corvette filter the return is the center pipe.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Feb 2006
      Norway
      Thanks, that's what I thought. Will try to start it up tonight after work then!!!
      May 2002
      Northern California
      ...just a note. if those are the hoses and clamps you are using please make sure they are the proper fuel injection hoses and clamps. At 52psi regular hoses and clamps will not do.
      fittings
      On the motor side, I used the piece from S&P. Its a piece of hardline that snaps into the filter and has a threaded fitting on the other end. On the tank side I used these things called Swageloc fittings. They're compression type fittings from the "Swageloc" store here in Phoenix, AZ. Worked great.
