    Results 1 to 11 of 11
      May 2007
      Midwest City, Ok
      Power steering feel without power steering
      What is the best way to get the closest feel of power steering w/o actually having power steering?
      Feb 2007
      East Freetown, MA
      I just close my eyes and make Vrooom, Vrooom noises.....
      Is there another way to phrase your question?
      Welland, Canada
      I'm thinking he means, what manual box would be similar/closest feel to a power box?
      Dean
      69 Camaro 355-3.73 Moser Truetrac-TKO600-Hotchkis-DSE-QA1's-Baer's-17"Budnik's
      ST U/LCA's-GW Del-a-lum's-Lee p/s
      May 2007
      Midwest City, Ok
      Quote Originally Posted by 69HuggrrrPT
      yes exactly! what steering box or what rack and pinion setup, would give me the most "power steering" feel?
      Feb 2007
      East Freetown, MA
      If there was one that did that, why would anyone need a power box?
      Take some weight off the front of the car and the effort will be less... Narrower tires will do the same...
      May 2007
      Midwest City, Ok
      Quote Originally Posted by Goatman
      I never said that I wanted the car to steer exactly like a powersteering car, because I know that is not possible. What I said was; what setup would "most likely"!!
      Aug 2005
      Patterson, NY
      I still think you need to clarify.
      To my way of thinking, there is no "feel" to power steering. It merely reduces the effort required to turn the wheel. (I know that statement isn't totally correct, but hopefully you see my point.)
      You could install a slower-ratio manual box, which would reduce the effort, but require you to turn the wheel more.
      You could adjust the alignment, bringing caster (or is it camber?) close to zero. This would reduce the effort required without dropping the ratio.
      Atlanta GA
      my guess hes asking.. "what box makes it easier to steer" or the latest hit.. "what box makes more turning power at slow speeds"
      Feb 2006
      SoCal
      Lower your scrub radius...........
      ***Under Construction***
      Build Update Link:
      Aug 2005
      Patterson, NY
      Quote Originally Posted by novanutcase
      There you go, the correct solution.
      Now, for my information, and possibly others', how would you reduce the scrub radius?
      Aug 2002
      Sweden
      Country Flag: Sweden
      Quote Originally Posted by GetMore
      New front rims with more backspacing.
