    Results 1 to 10 of 10
      St.Anne Il
      locked up muncie
      took my newest 69 vert around block today and about halfway i couldnt shift it anymore..i believe its in second gear as its not bogging reall bad on take of and i can drive about 30..any ideas..i worked linkage and sprayed crap out of it with lube..im new to the trans work stuff..any idea on how to see whats bad without pulling it?
      Darrin Stalnecker
      2007 Corvette Supercharged
      1968 Camaro LS1 T56
      Chicago - western burbs
      I'm not an expert, but it sounds like the shift rods are just not adjusted correctly.
      Rockford Illinois
      Sounds like one of the bushings wore out on the linkage,the plastic ones are the worst offenders. Replace them with the bronze bushings if they are worn.
      CHICAGO SUBURBS
      After the trans get old the linkage will get stuck in a gear. Jack up the car, under the bottom of the shifter, there is three levers. When in neutral they should be all centered fron to back. Find which lever is moved and move it back to center. I have used a large crecent wrench. When the arm are centered and the trans ans shifter are in neutral there are 1/4 inch holes drilled in the arms, side to side. There need to be EXACTLY lined up. You can use a 1/4 drill shank. If you have any questions I can send you my number and talk you through it. Adjustment depends upon style of shifter. Basically shortening or lengthening the shift rods. There also are detent bolts for stopping over shifting. Hope this helps!
      Aug 2003
      Not a original Muncie shifter is it? there are infamous for knoting up. It is because the ****er mounts to the crossmember and does not move with the engine. As stated above, just center the shifter ears.
      St.Anne Il
      Hilrod thanks a ton i will try that...if nothing else im near chicago and will pay you to help me..lol..but think i can handle it..Frank not sure if its original or not..driving my other 69 4 speed alot and its never locked up yet..lol..
      Darrin Stalnecker
      1968 Camaro LS1 T56
      Feb 2007
      USA, TN
      Sometimes you have to unhook all the rods and get the trans into neutral by hand. It could be internal, but the shifter is the most likely suspect. If the shifter or linkage is bad or really cheap, it will sometimes try to move to levers at once causing your problem
      St.Anne Il
      ok got it unstuck..shifter says hurst on it..but it seems really sloppy underneath...someone told me about a bushing kit to rebuild it .can i find this at most places? needs a little more brake work before i drive it again anyhow..
      Darrin Stalnecker
      1968 Camaro LS1 T56
      Aug 2003
      St.Anne Il
      thanks Frank !!..figured so ..i just got back from garage again..didnt lock up till i put it in 3rd..so i can drive it just not to fast..lol..
      Darrin Stalnecker
      1968 Camaro LS1 T56
