Thread: rotor ideas
05-21-2007 #1
rotor ideas
hi
i'm looking for some 13"-14" rotors for my charger
i will be using hubs to replace the factory style rotor with the 1 piece bearing hub/rotor
i need rotors with a 5 bolt pattern and a 2"(approx) deep hat to clear the viper calipers most newer rotors have very little hat to them
i've ruled out late model corvettes, mustangs, cherokees, gm trucks, 300's, vipers(6 bolt),
i have a limited budget so i can't do the wilwood/baer swap
porshe caymans would work but are almost a $1000 a pair
mercedes may work but i'm hoping someone can recommend some options
below is a pic of my original style rotor
i need something with a similar offset hat
thanks jason
1974 charger se modified, 440 727 3:23's, twin turbo t61's,intercooled,custom mpfi,55lb inj, ms1 v3- 2.36,msd6a,msd coil,big rims(20's/22's,4 disk brakes,smoothed, slammed, and scary fast
http://members.shaw.ca/viper11/
05-22-2007 #2
- May 2006
- 115
Ive been involved in an install where we used BMW rotors on the old hubs (believe the hubs were ford GVM thet were redrilled for GM pattern), not too expensive and excellent quality.. they have about 1.5-2 inch tall hats and come in sizes up to 14 inches... go down and have a char with your local parts guy and take a look at them..
05-22-2007 #3hey deuce
any particular era beemer???
p.s hat depth is the term I was looking for when i was typing it out duh
i will edit it to make more sense
thanks jason1974 charger se modified, 440 727 3:23's, twin turbo t61's,intercooled,custom mpfi,55lb inj, ms1 v3- 2.36,msd6a,msd coil,big rims(20's/22's,4 disk brakes,smoothed, slammed, and scary fast
05-22-2007 #4
