    Results 1 to 3 of 3
      TuoCo, CA
      Which Master Cylinder?
      How can I determine which Master Cylinder to run. Here's my setup:
      C5 Fronts with Wilwood Dynalite 4 piston Rears on in the 68 Camaro. It's a manual brake system and may become a hydraboost next year. I was wanting to run the wilwood dual resevoir aluminum master cylinder. Should I be looking at a 1" or 1.125" or something all together different.
      How is the piston sizedetermined? It seems to be a frequent question asked around here and I like to understand how the master cylinder piston size should be determined other than by trial and error.
      TIA.
      Steve
      Check it Out Here
      Southern Indiana
      The smaller diameter will build preasure faster .
      See drum brakes run by volume and disc run by preasure.
      disc run only a few thousands of clearance where as drum can have to take up .020, .030, or even more so you have to move LOTS of volume.
      I also prefer to run 3/16 steel line all the way round too.
      anyway good luck and ask lots of questions.
      On manual I would run the 1.00" .
      Lee
      TuoCo, CA
      Thanks, I think I'm so clueless at this point I don't even know what questions to ask... pressure v. volume makes sense, how do you determine what the pressure requirements of a system is?
      On a hydraboost system would you look run the 1.25? Why the difference?
      Steve
      Check it Out Here
