      San Antonio, Tx
      master cylinder question
      putting a T56 in my 67 camaro, i'm useing the wilwood pedel assembly insted of making the factory pedels work. my question is what size master cylinder do i need for the factory slave cylinder/throwout bearing? the wilwood master cylinder kits come in 3/4", 7/8" and 1" bores, i was thinking of going with the 7/8" to give me a light pedel like the new C6's or the 1" bore and have next to no pedel like the C6 Z06 lol. what do you guys think?
      Instagram: CamaroAJ
      San Antonio, Tx
      my bad, the master cylinders also come in 5/8, 13-16 and 1 1/8. also a bump, wanting to get a master this week maybe next week.
      Instagram: CamaroAJ
      Encinitas, CA
      The bigger the master cylinder bore the stiffer the pedal and the shorter the travel.
      A stock GM master cylinder for a 2000 Camaro (for example) has a 3/4" bore.
      Use a 3/4 bore or 13/16" bore master at largest if using a 2000 +/- Camaro hyd to bearing.
      Also, make sure you mount the MC push rod approximately 2-2.25" below the clucth pedal pivot point - if you mount much lower your pedal will be hard to push and your travel will get too sort.
      Jeff Mortenson
      Dec 2002
      Lost Wages, Nevada
      ... and try and build in a pedal stop.
      San Antonio, Tx
      i should have put in that its a 2002 T56. thanks for the help guys, chicane that is on my list of things to do once i get the master cylinders in so i don't brake the internal snap rings.
      Instagram: CamaroAJ
