      Aug 2005
      Patterson, NY
      Housing ends and backing plates
      I'm not sure this is the right section, Mods/Admins feel free to move it if needed.
      Anyway,
      I am planning on having Ford housing ends welded onto my 10 bolt rear axle assembly when I have the tubes welded to the pumpkin. I wanted to get rid of the c-clip setup. I'm also changing over to a Baer rear disk brake setup.
      The housing ends have the same bolt pattern ("small Chevy") as the housing ends currently on the stock rear. The new ends use the "large Ford" bearings.
      The caliper mounting brackets also have the "small Chevy" bolt pattern.
      Here are my problems/questions:
      The ID of the Ford housing ends (where the bearing seats) is larger than the opening in the caliper bracket. This means that the bearing will not fit through the caliper bracket.
      The bracket's opening doesn't seem to be small enough for me to cut a slot in the bottom and use it as a retainer.
      How wide is the Ford bearing and the standard Ford backing plate?
      Does the bearing typically stick through the backing plate and then a retainer plate is installed to hold the bearing in place?
      Should I machine the hole in the bracket larger, to allow the bearing to fit through?
      How did I get myself into this mess?
