    Thread: need help!!
      livermore ca
      need help!!
      on my 95 lt1 i added fittings to the fule rails iam in the process to putting everything back together and one of are friends came by he works at ford and said that i needed a shrader valve to perssuerise the fuel in the rails becuase if i didnt have one the fule would just cycle through the rails and never get enought peressuer to go through the injectors. so he said instead of running a fule return hook the line up to a fule perssuer gage? will this work or do i need a return ill try and find a pic of my set up.
      thanks chris
      https://www.pro-touring.com/forum/sh...ad.php?t=22724
      65ss chevelle
      95 lt1 LE2 heads gm847 cam, 1.6 gold sereis roller rockers,52mm tb,37lb racetronix injectors. hooker headers
      63ss nova
      350:cam headers,roller rockers.pete jackson gear drive,
      th350 shift kit 3,500 stall
      3:73
      **Drive it like you stole it!!
      livermore ca
      nm i fixed my own problem!
      65ss chevelle
      63ss nova
      3:73
