      Fort Campbell, KY
      Proposed L92 build up
      I decided on a L92 6.2L N/A for the 68 GTO as the LS2 is /will be discontinued. Goal is arround 500 - 550 rwhp, auto 4L60 & 3.70 rear ratio. It might be cheaper to build a N/A LS2, I don't know enoughf to speck one out.
      Well here is my plan, so please help me out here as I might be doing this the hard way.
      buy a L92 6.2L and add or swap out parts instead of having one built.
      I came accross a ebay auction for a 07 escalade engine listed on Ls1tech. It is cheap, almost two cheap....
      http://cgi.ebay.com/ebaymotors/ws/eB...0932624&rd=1,1
      starting @ $2,8000 + s&h
      I pm the poster and he said he will send me pics to confirm that the engine is legit. I have not heard back from the ebay seller yet.
      This should be the same engine, for a price comparision:
      I don't know what intake the 6.2L L92 below comes with. I am goining to assume that it would be the truck intake.
      GM PART # 19165485
      CATEGORY: Eng Asm (shipped only to local fedex hub 4 pickup)
      PACK QTY: 1
      CORE CHARGE: $0.00
      GM LIST: $8,142.86
      OUR PRICE: $5,928.00
      At a minimum for the ebay motor I need the altenator & bracket, belt, ps pump, ac compresor (I might go with vintage air) engine computer & wiring harness.
      I want/need:
      L76 car intake ?order it bare as I can use the fuel rails& TB?
      Ls7 style 60lb/hr? as the stock injectors are 39lb/hr
      Livernois Motorsports L92 Camshaft (Stage 3 )
      Livernois Motorsports CNC Ported Stage 3 L92 Cylinder Heads
      GM Performance hydraulic roller lifter set part # 88958689 from SDPC (is this lifter set over kill?)
      ATS LSX road oil pan
      new cylinder head ceramic gaskets?
      ported oil pump
      ARP head bolt set
      Anthing I am missing parts, items ect....???
      VS:
      starting with
      L92 416ci Short Block Assembly from SDPC part # SDL92SB416D10
      I know the factory block does not come with ARP bolts or anything else the SDPC short block does.....
      should I bother with having a complete custom block built?
      I don't know enoughf to speck one out...
      TIA
      Josh
      1968 GTO https://www.pro-touring.com/showthre...ject-Grey-Goat
      Trying to accomplish the impossible, with no resources in the minimal amount of time possible.
      Nov 2004
      dayton ohio
      only one feedback, you cannot pick it up, only picture i got. stay away stay far away from that seller/item. call and talk to scoggins/dickey ask for their ls1tech rep.
      Feb 2007
      East Freetown, MA
      It will be cheaper to build a LS2 for sure. Again I suggest more research........... You should know everything you can about the entire family of engines before deciding on anything.
      That e-bay engine will probably end at around $5000 the way I've been seeing the LS2's go.
      All that stuff you'll need for the e-bay engine will run you at least $1000 from what I see. And you'd have to run across a deal and a half to "just" spend that much. You'll want all the accessories from a F-body, if they'll bolt on. With this new motor, I'm not sure if they will.
      I'm not sure you'll need all that injector. As I stated in one of my other posts to you. The LS-x engines run a much higher fuel pressure than do most engines and the injector calculators don't take that into consideration when they calculate which injectors you'll need.
      Pretty sure you won't need that cam or that much port work, but contact whoever you're going to use and TALK to them about what you want.
      Not sure what GM is doing for head bolts on this motor, but the other LS-x motors all use head bolts that can only be used once, then you have to throw them out. You may want to factor in a set of ARP head bolts as well, if ARP even makes them for this motor.
      I would add a ported oil pump to that list as well.
      Again, if you don't know enough, either commit the time and energy to learn, or buy one done. Its going to ocst you either way. There is no easy way out.
      Feb 2007
      East Freetown, MA
      For frame of referrence, here's what I've got so far:
      03 LQ9 6L engine, complete with harness: $1500
      Sold intake: -$40
      Stage II ported 853 heads, complete with new springs for .650 lift: $700
      Haven't sold stock 317 head yet, but they're going for $200 pretty much everywhere.: -$200
      FAST 90mm intake: $700
      S&P fuel rail: $175
      160 degree thermostat: $40
      CTS-V oil pan: $75
      Pickup for pan (GM dealer): $40
      SLP ported oil pump new: $150
      Ported Mecham MAF: $80
      2000 Camaro water pump: $15
      Most of these parts I bought off people who had changed directions and got a deal on them. My goal is about 450-500 rwhp, the actual number means nothing to me, I just want it driveable, with the A/C on.
      I still need a throttle body, injectors, headers, ARP hardware, and a bunch of factory sensors, gaskets and bolts.
      So that's a taste of what you'll be looking at, if you can put in the time and effort to find the deals. If not, you'll be spending alot more.....
      Atlanta, GA
      Quote Originally Posted by josht
      GM PART # 19165485
      PACK QTY: 1
      CORE CHARGE: $0.00
      GM LIST: $8,142.86
      I want/need:
      ported oil pump
      ARP head bolt set
      VS:
      starting with
      TIA
      The 415 will give more tq. than a H&C L92. Is it worth the coin? All depends on what you want. TEA has come out with a good L92 CNC program as well and IMO their customer service rocks.
      I would swap ARP rod bolts into any factory GM shortblock while it is out, cheap insurance with minimal work. Most if not all LSx head bolts are tq to yield one use bolts. I used ARP studs on my H&C LS1, they are stronger and reusable besides it makes it easier setting the head down on the motor.
      Also look into a nice timing chain. I went double roller which required some clearancing on the timing cover for an LS1. I am not sure about LS2 or newer shortblocks. It is most likely overkill but the motor was built for track events and some pretty hard moutain runs. 40k after H&C with ~90k total on the shortblock it is still alive. The only things replaced have been the fluid changes and the valve springs after 30k which I recommend with any aftermarket cam.
      I am fairly certain accessories and head studs from any LSx will bolt on the L92. LS1tech has more info. A friend just put a 415 L92 in his '98 TA but I did not ask if he ran into any problems.
      SDPC has received some good reviews on LS1tech. If you buy the shortblock be sure the PCM you buy is for the reluctor wheel on the crank Gen3 and Gen4 motors are not the same.
      Lamar
      00 C5 hardtop H&C 436 rwhp with an 04 Z06 Suspension
      70 Chevelle SS396
      Feb 2007
      East Freetown, MA
      I agree about the rod bolts, and I would add the head bolts too. In fact, I did on mine.
      And I'm probably going to buy a set of ARP main studs as well.
      An LQ9 core from a salvage yard should set you back no more than $500, a Callies Dragonslayer crank, some good rods, over the counter L92 heads, intake. Youll be able to hit 500hp easily and cheaper than with an L92 as a starting point, cams will be cheaper and youll have a much wider selection(no VVT to deal with) you can use readily available accesories without the adapters the L92 would require, and you get 24x timing and therefore more choices for engine management(though Mast and I am sure others offer VVT controllers)
      Id start with a 6.0L without a doubt(or aftermarket block like the GM LSX or a Warhawk.)
