Results 1 to 11 of 11
Thread: firebird 400 swap
05-10-2007 #1
New to Pro-Touring
- Apr 2007
- 6
firebird 400 swap
i need a walk-through on how to install a 400 (w/ 5 engine mount bolts and 11bolt wp) into a 67 firebird that was orginially equipt with a 326
05-11-2007 #2
- Mar 2006
- SW Wisconsin by Dubuque, IA
- 77
I believe all Pontiac V-8's are the same size, and all bolt in the same. I could be wrong though.
RonStroked LQ4 (402ci), Twin 62-1 Turbos, Viper T56 M6, Moser 12 bolt w/ 3.42's.
05-11-2007 #3
- May 2005
- Houston
- 215
If you have a five bolt block you can use your original motor mounts. And all of your accessories should bolt up as long as the heads have all of the mounting holes. You shouldn't have any problems.
Wick
'71 Camaro RS Project
05-11-2007 #4
Banned
- Feb 2007
- East Freetown, MA
- 513
Its a bolt in deal. Everything is the same.
05-11-2007 #5
New to Pro-Touring
- Apr 2007
- 6
"In addition 1966 and earlier blocks had 2 freeze plugs on each side of the block. 1967 and newer had 3 freeze plugs per side.
These blocks had 2 motor mount holes per side.Starting in 1970, most blocks were cast with 5 motor mount holes with the mounts using 2 bolts in line with 1 higher up in the middle.Some 1977 and later blocks only had 3 holes that used the newer mounts."
the 400 block im using is a 71 with 5 mountnig holes. does this mean i can use the 67 326 engine mounts and just use 2 holes?
05-12-2007 #6
Banned
- Feb 2007
- East Freetown, MA
- 513
If you're not going to put alot of power to it.
But why not just buy new ones? They're not expensive........
05-12-2007 #7
