    Thread: front end clunk
      front end clunk
      im having a clunk in the pass. side front when i take a left hand turn. the clunk is consistent with the wheel rotating. im going to tear it apart tonight if i get time but was looking for hints on what to look for so i can hopefully drive it this weekend. its a 67 camaro with a bbc by the way.
      Fontana, CA
      Idler arm, loose or worn ball joint or tie rod. Those are the first things I would look at as well as ensuring the UCA bolts are tight.
      Nick R.
      Quote Originally Posted by kman67rsss
      Wheel bearing not properly preloaded, or possibly failing?
      Nov 2000
      O-town
      Oh Why did you leave me loose wheel!!!!
      My Nova does the samething studs are shot !
      when i got under it in the rear i found a loose traction bar, tightened it up and it seems to have taken care of the problem.
      California
      Quote Originally Posted by Steve68
      I actually had that problem. I usually tighten the lugs as much as I can, but I figured I'd look up the torque in my Haynes manual. I think it said like 70 ft lbs so I did that, and somehow they still broke loose. Of course I didn't know what the noise was, and by the time I found out, one of the lugs had been broken off.
      Matt
      Nov 2000
      O-town
      Mine are loose in the rotor, so instead of buying new rotors I going to do a C4 brake upgrade and I have a Baer rear kit coming, brakes done!
