Results 1 to 16 of 16
05-09-2007 #1
totally stumped electrically...HELP
I'm only getting about 11V on the Autometer gauge in my Chevelle and can't find the #$%&! cause.
Last weekend it seemed to be fine, reading about 14V at cruising speed and around 12 at idle, then I noticed it was only reading about 11 just before I got back home. Since then it showed 14V briefly when running in the garage, then dipped to 11 and hasn't budged since. Changes in engine speed have no effect on gauge reading, as if it's only reading static battery voltage. Battery reads 12v at key off. I figured I had a ground issue.
I have a one-wire alternator run by a March serpentine set-up. Since the alternator, bracket, and heads are all aluminum I've run a separate ground from the alternator to the chassis. Checked that for continuity and it's good. The block is cast iron and the motor mounts are all steel, no rubber. Have even run an add'l ground from motor to chassis, didn't help. Am getting voltage from the battery thru the alternator lead, as evidenced by the arcing when I mistakenly touched the lead against the head. Swapped the alternator for a new one, no change in readout.
Can't seem to get the alternator to excite (or at least read that it is) no matter what RPM the motor runs at. With the motor running the gauge reads about 11V. Turn on the parking lights and it drops to 10.5, add headlights and it drops to 10 so the gauge appears to be working.
Any suggestions on what else to look for or steps to take at this point? My background is mechanical engrg so talk slowly...
Thanks in advance.
Bob
Mooresville, NC
'66 Chevelle SS (461, T-56)
https://www.pro-touring.com/forum/vb...?do=view&g=274
