Thread: torch cutting set up??
05-09-2007 #1
I just got set up with tanks and torch. I will mostly use it for cutting but I have a brazing set up as well. Question is what pressure setting should I use on the oxygen and the acytelene? Thanks!
05-09-2007 #2For what?? Cutting, brazing, welding??? 5:1 ratio for cutting, ex. 7 acetelyne/ 35 O2. But it really depends on your tip size and what thickness you're cutting.
The needs of the many outweigh the needs of the few.
05-10-2007 #3Primarily for cutting, chassis and frame thickness. I am not sure of the tip I have now.
05-10-2007 #4Try to get a 0 or 1 tip size. Start with 5-7 for acetelyne and 25-35 on oxygen. Practice with scrap first, or you have a good chance of making scrap.
05-10-2007 #5Thanx toxic
05-10-2007 #6
Not a problem!
05-15-2007 #7
