      Nor Cal
      Centerforce Dual Friction or newer DFX?
      I have done a search on this site and a couple others and really couldn't find an answer, and I can't really figure out the big difference from the language on Centerforce's website either.
      Any insight? thoughts? recommendations of these 2 models?
      I will be running between 600-700 rwhp, depending on pulley size I use, but will use street tires and a TKO 600 for street driving only... no 4000 rpm launches with slicks for me... at least not for now.
      thanks
      1968 Camaro widebody project
      2004 Mustang LS2
      1964 Continental
      2014 Keezer
      Aug 2001
      Connecticut
      Don't even bother with the dual friction at that hp; I went through several on my old 358 making 550hp at the crank. I'm using a centerforce light metal series on the 427 and like it- it is between the DF and DFX in their charts (I think it was rated for 600 or 650 ft-lbs), but drives nice like the DF. If you are serious about 600-700 at the tires, maybe the DFX, but more than likely a 2 disk clutch. More important than hp though is torque rating.
      1962 Corvette 327-340hp stock
      1967 Corvette L79 convertible
      2006 Corvette Z06
      2011 Corvette GS convertible
      Nor Cal
      I am just trying to get maximum streetability and the least amount of pedal stiffness, and with minimal chattering. Yes, like all things, I guess it is trade off at some point, but you hear so many variations in experiences.... just looking for first hand feedback and insight.
      Here is what the Centerforce rep emailed back to me:
      Hello Dave,
      The DFX ( DUAL FRICTION EXTREME )in the 11" application will handle up to 850ft.lbs. of Torque to the Crank, more of a racing clutch with 6 puc sprung hub w/ metallic button material, hooks up faster than the DUAL FRICTION and not as street able. The 12" application with part number DF612909 will handle 700 ft.lbs. of Torque to the Crank and a very street able clutch. The DUAL FRICTION will handle up to 625 ft.lbs. of Torque to the Crank.
      I am thinking maybe the DFX 12"? I hear of so many people having good luck with the DF and other "lower rated" clutches because they drive them on the street only with no slicks and no hard launches at t he track, which is what my program is....
      2004 Mustang LS2
      1964 Continental
      2014 Keezer
