      Melbourne, FL
      Single piston replacement
      I currently have the large GM single piston calipers on the front of my 67 Bird. Which caliper would be a direct replacement/upgrade for these calipers ???
      67 Firebird Convert 455 +.060 Johnny Winters TH400 74cc KRE d-port flowed @ 310 cfm heads piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
      Honest dad that 455 on the side of the block is a serial number
      Chico, California Nor-Cal
      Wilwood makes the GM III, Make sure you look for the one for 1" rotors, and has the vibration o rings like stock calipers. You must use braded lines as the fitting on the caliper are different. They are about $95 ea, and weight about 10 lbs ea. less!
      Keith
