    Thread: Longer t-bolts
      Niceville, Florida 32578
      Longer t-bolts
      I'm bolting some '99 Camaro rear discs onto my '67 Firebird and I need some longer t-bolts to mount the aluminum bracket to the end of the axle housing. My Moser 9" axle flange and the aluminum bracket are just too thick for the Moser t-bolts. Any ideas on where I can get some longer t-bolts? Thanks.
      All that is necessary for evil to succeed is that good men do nothing.
      Edmund Burke
      Los Angeles
      Personally, I used the bolts that were on the LS1 rear. I don't know if you'll find longer T-bolts, but you could go to a store and get grade 5 or 8 bolts and washers, or flanged bolts.
      Kettering, OH
      There are some Ford t-bolts that are longer and are the 3/8" diameter required. You can get them through AMK Products if you can't find them locally.
      I'm doing the same coversion on my '67 Firebird. How are you handling the e-brake and who made your brackets?
      Quote Originally Posted by Hammered
      Not sure about the emergency brakes yet but will probably just weld some brackets to my lower Cal-Tracs plate.
      Edmund Burke
