      Bonney Lake, WA
      Inner Tie Rod Options.
      iVE GOT A LITTLE CLEARANCE ISSUE ON THE INSIDE TIE ROD TO OIL PAN CLEARANCE, HAS ANY ONE ELSE DELT WITH THIS? Im running a canton road race pan. stock manual steering. about 2/3s the way in to turn the zirk fitting catches the pan. if the zirk were clocked differently or it was a sealed unit or low profile unit it would probably work. has any one seen options like these to alleviate the problem?
      Feb 2007
      East Freetown, MA
      Yep. It involves a hammer and a length of small diameter pipe. place the pipe along the pan (rounded edge where you need the dent) and gently tap the pan untill you get what you need.
      Bonney Lake, WA
      Will Heim Joints Work?
      What About Heim Joints? Are They Safe? Has Anybody Else Here Used Them In There Steering Linkage?
      Feb 2007
      East Freetown, MA
      They tend to get alot of road debris in them....
