Thread: LT1 and LS1 T56???
LT1 and LS1 T56???
If I have an LT1 and an LS1 T56, and the LT1 T56 has bad syncros, can I swap my LT1 input shaft, and bell housing over to the good LS1 T56. will this work?
Thanks.
1974 Nova, 383, T56
2006 Kawasaki ZX6R
"Going fast is looking good"
04-30-2007 #2
Starting The Transformation
- Oct 2005
- Lima, Ohio
- 216
The clutch styles of these two trannies are different. One's a pull and the other a push.. That said I don't think it would work with just changing the shaft and bellhousing.
05-01-2007 #3
- May 2005
- 140
supernovabjt,
I don't see why not? You will need to switch over the input shaft, transmission adapter plate, and bellhousing. As long as the input shaft 4 th speed gear and clutch teeth are in good shape it should work. There is a shimming procedure to check for end play after re-assembling, which may require changing out shims at the input shaft.
Go to the Tremec website and download service manual to see what you're getting in to. http://www.ttcautomotive.com/
John
