    Thread: Bleeding brakes
      florida
      Bleeding brakes
      I have done the LS1 disc brake conversion on the front and swapped to a power brake setup. I do not have the vacuum line ran to the intake manifold yet, and I am trying to bleed the brakes. I pump and pump and pump the brakes and Im not getting anything out of the bleeders on the calipers. This power setup is new to me, do I have to have the car running and and under a vacuum to bleed the brakes???
      Fontana, CA
      It does not need to be running. It helps, but is not required. How are you bleeding them?
      Nick R.
      florida
      pumping them up about 10 times and holding to the floor then opening the bleeders. I hear the port for the vacuum line sucking air when I pump them. I am beginning to think my brake rod isnt pushing in the master cylinder far enough. But it sure seems it shoul dbe pumping atleast some fluid out at the calipers...
      Fontana, CA
      If you are running a short style rod between the two with a deep style MC then the brakes are not engaging at all. The bottom of the page has an illustration of the difference in MC styles.
      http://www.hydratechbraking.com/products/1stgenfbody/
      Nick R.
      florida
      Thanks for the help I will pull it all back apart tomorrow and see exactly what I have.
