    Page 2 of 2 FirstFirst 1 2
    Results 21 to 40 of 40
    1. #21
      Red Deer, Alberta, Canada
      Quote Originally Posted by whytry
      Perfect, thanks Matt. I was wondering about fitting a panhard with a stock tank... I have some ideas from your pics. Thanks again!!
      Yea its tight but totally do-able. If you need any more reference pics or info just ask. I'll gladly answer.
      Matt
      Instagram: Cst_koon
    2. #22
      Feb 2006
      BC Canada
      Matt, If the intake works I don't give a s#!t what it looks like. I don't red line my engines much anymore. A torquey around town and hiway engine is what I need. Can't get a whole lot of tire on those cars unless I get into the quarters which I can't see myself doing in the near future..
    3. #23
      yea, I should be able to get you an ls1 intake for pretty cheap. They were throwing out truck and ls1 intakes! thats how brutal and how swamped they got a couple months ago! let me check for ya.
      Matt
      Instagram: Cst_koon
    4. #24
      Feb 2006
      BC Canada
      Hi Matt, don't get an intake on my account just yet, I haven't even got an engine yet. I'm looking to find a late model all aluminum 6l truck engine.
      Does anyone know the LQ designation for that one?
      Frank.
    5. #25
      You wont be able to find a all aluminum 6.0l truck engine. The LS2 is a 6.0l all aluminum block/heads deal.
      The new l92(or whatever it is), may be a aluminum block but I doubt it. They just changed up the displacement, heads and intake design.
      Matt
      Instagram: Cst_koon
    6. #26
      Feb 2006
      BC Canada
      Matt, I thought the '06 and later 6.0's were all aluminum......
      What is the L92 avilable in?
    7. #27
      Oct 2005
      Ferndale, WA
      The 6.2 L92 engine is all aluminum
      72 Chevelle Done!
      67' Hell Camino- Under the knife
      Some day: Porsche GT3/ C6R inspired 69
    8. #28
      Feb 2006
      BC Canada
      I just did a little on-line searching. L76/6.0L, all aluminum - late '06 and later. Sierra's, Avalanches, Suburbans, etc. Sounds like a good choice.
      Everyone will be clamouring for the L92/6.4L - 380hp.
      Cool stuff. Anyone wanna buy a Holley Throttle Body Injected SB400 this fall?
    9. #29
      Miami, Florida
      Matt what shifter are you using with your 4l80? have a friend putting one in a 1969 camaro, I was thinking of replacing my th400 with a 4l80 but the choise of shifter has me on hold.
    10. #30
      hey,
      I used a pro ratchet B&M shifter. Let me dig up the part number.
      edit: this is summits part number. BMM-80842. The shifter is for a th400, the pro ratchet allows you to pull a pin out which allows you the full selection of gears.
      If you have any more questions let me know!
      Matt
      Instagram: Cst_koon
    11. #31
      I might aswell throw an update...
      Car ran flawless all summer. I installed a 12 bolt 4:10 limited slip rear end. Magnaflow mufflers attached to 3" exhaust from Hooker Super Comp LT headers.
      The car would destroy the 295s in 1st and continue sideways into 2nd. The odd chirp into 3rd too. Stock 4l80e tranny, no stall, or anything.
      1st day the car rolled out under its own power this year.
      All together and at a show.
      And apart for winter
      Matt
      Instagram: Cst_koon
    12. #32
      Feb 2006
      BC Canada
      Matt, Impressive performance for stock powertrain. Whats up with your car for this off season? I was over in Calgary this summer for the Canadian Power tour for a couple of days, got tired of the rain so I came home. I would like to touch base with you some time and look at your car. It looks like my Corvette my not get the ls conversion this off season [again].
      Best of the new year to all......
    13. #33
      Quote Originally Posted by 00fxd
      Thanks for the kind words! Hopefully the car will make a run out to BC this year. Vernon/Kelowna/Penticton area.
      For winter time I'm going to try and force feed her. I would like to get it running with the hair dryer and then next winter possibly slugs, hardware, and shift kit along with a fuel safe cell. I want it on the road for "Super run 09" so I do bits and pieces each winter. That way its a completely new car every summer it rolls out of the garage.
      Matt
      Instagram: Cst_koon
    14. #34
      Feb 2006
      BC Canada
      Matt, do you have dates for you trip? I'm definately the Osoyoos Cactus Jalopies run June 21-23 http://www.cactusjalopies.com/ . Rat rods and stuff.
      A good old time deal, engine blow-up, a real burn out contest [no chains] and a drag race at the air port run way. Rat rods and stuff. We ended up at this place for the BBQ. Unbelivable. Hot as hell there.
    15. #35
      I usually go the first 2 weeks in july and the first 2 in august. I may alter it this year though. Depends when the car is back on the ground and driveable lol.
      That run would be a blast!!!
      Matt
      Instagram: Cst_koon
    16. #36
      Miami, Florida
      Matt. that is the same shifter that I have in my car I really liked the way it looks and operates. So you are telling me that that shifter has a pin that I can pull out and make it a four speed shifter? Can you ratchet through all the gears with it in your car or just leave it in gear.
      I also am thinking about using C6 ZO6 rims in my 1970 chevelle what size spacers are you using in the front and back and what sizes are those rims? I also looking into the coleman set up that Denis came up with how does it feel?
      Thanks for your help. One day my car is going to have that same stance
    17. #37
      That is correct about the pin in the shifter. If you have your instructions for the shifter it should list which pin to pull.
      I can ratchet through all gears and also put it in drive and just go.
      Spacers are 2 1/8" front and 2" rear if I remember right. Its been a while. I think the c6 back spacing is different from the c5.
      They are 18x10.5" rear and 17x 9.5" front
      The coleman setup works great. I really enjoy how the car handles. Much more forgiving now, The car turns tighter then my civic and feels very stable.
      Thanks for the compliments.
      Matt
      Instagram: Cst_koon
    18. #38
      Feb 2006
      BC Canada
      Quote Originally Posted by protour_chevelle
      Matt, I just got word that the 'Cactus Run' is not a go for this year .
      If you do come through, let me know, we'll hang out.
      Frank.
    19. #39
      Frank.
      what the helll?!?! Did they say why?
      and I'm down for hangin out if I pass by!
      Matt
      Instagram: Cst_koon
    20. #40
      Miami, Florida
      Matt. I found the pin you told me about on the Pro ratchet, my car is at the tranny shop getting a 4l80e that I got a good deal on can wait to try the car out. Your trans is D.3.2.1? Is there a reverse valve body for a 4l80e?
      Do you have a part number list for the Denis coleman stuff? What did that run you, how does the car handle.
      Ps What brakes can be run C5?
