Results 1 to 12 of 12
Thread: HP on a stock 4l80e
- Jul 2005
- Miami, Florida
- 168
HP on a stock 4l80e
How much HP does a stock 4l80e hold? I have a 540 in a chevelle with a manual valve body th400 and I love untill I get on the highway and them I'm in pain!
Found one at a truck yard for $500.00 looks like a deal. But I have some questions.
1. How much HP can it handle stock.
2. Will my flyweel work.
3. What manual ratchet shifter will work with this trans.
04-22-2007 #2
Starting The Transformation
- Jun 2005
- 467
Here's a couple answers:
1. 500HP seems to be the consensus, and maybe 600ft/lb of torque.
2. I believe the TH400 flexplate will work, but the bolts to the converter will change to metric. ARP makes some good ones.
3. Any ratcher shifter for an OD tranny should work, but check the application guide. I know B&M sells a few, and Lokar too. Lokar also has a strong cable kit that goes between most ratchet shifters and the 80E.
If you can spring for a controller and harness, the programmable part of the 80E is great. It allows you to dial in upshift/downshift points per gear, line pressure vs. TPS per gear, datalog including temps, and much more.
TransGo makes a really nice shift kit for the 80E, and it is compatible with the TCI controller or a manual valve body.
Rossler now makes a transbrake for the 80E. Unfortunately it does not work with the Transgo shift kit, but it does work with others.
JimDon't take a knife to a gunfight.
Half-Assed = Half-Fast
04-22-2007 #3
- Nov 2004
- Colorado
- 1,260
