      Jun 2006
      Mason TN
      Problems with my new engine, need direction please..
      I picked up my nw engine today and mocked it up only to find this problem, Now that I have AFR angle plug heads the #1 and #2 header pipes will not clear a plug on each side of the engine. As I see it there are only two choices;
      1) new headers
      2) have my current headers cut, rewelded and recoated.
      I am not necessarlly opposed to either solution, at this point whatever is faster and less expensive will work.
      Has anyone used a set of headers that clears everything including the angle plugs??
      Sheesh, this is depressing....
      BTW; this is for an 86 Monte SS.
      Thanks.
      NH
      I would say get the right headers but lets see a pic of the problem areas?
      Arlington,TX
      I think Schoenfeld headers might be what your looking for. I started a thread on MCSS.com awhile back asking members to post up some pics of their headers installed. I think they work with angle plug heads well.
      http://www.schoenfeldheaders.com/cratepage.htm
      Here's a thread I started on Maliburacing.com
      http://www.maliburacing.com/forum/vi...dee7c8c1ae8006
      BRIAN WEST
      SouthTX
      You can also try asking AFR, they should very well know what headers should work. Then compare notes with the feedback you get.
      Jun 2006
      Mason TN
      Thanks Guys, I ended up ordering a set of dynatech that should work.
      As far as calling AFR, has anyone tried it lately? I had no luck at all getting through to them. Thier customer service sux!
      Aug 2001
      Connecticut
      I have Hooker super-comp 1-3/4's on my afr's now and they clear; I'm switching to hooker 1-7/8 in the next few weeks- they look like they should also be ok. What brand and size headers are you trying? I believe Hooker lists if they will clear angle plug heads or not.
      1962 Corvette 327-340hp stock
      1967 Corvette L79 convertible
      2006 Corvette Z06
      2011 Corvette GS convertible
      Jun 2006
      Mason TN
      Like I mentioned I'm going with Dyna Tech headers, the open track design.
      They are supposed to fit real nice on the Monte and clear the plugs. I was told by Hooker that their super comps would only clear OEM angle heads and not the AFR's. I dont see where the difference is but with the problems I had with the Hooker comp headers I'm replacing I didnt want to take a chance.
