    Page 2 of 2 FirstFirst 1 2
    Results 21 to 33 of 33
    1. #21
      Nov 2002
      state of confusion
      Me, I've no real experience, other than some drag racing such a long time ago that it embarrasses me to say when it was.
      There are literally dozens of tips, but here's a few that I think are more important.
      Walk the course several times. If the club offers an instructed novice walk-through, don't miss it. Likewise, for a run, there may be the opportunity to have an instructor in the passenger seat - take full advantage of this (I don't think you'll have to twist anybody's arm very hard).
      Except for Pro-Solo, there is absolutely no benefit in having the best reaction time, as the timed portion of your run does not start until you've traveled several feet past the point at which you'll stage. A good, clean launch is all that matters.
      Expect to be told to "look ahead" and fight the natural tendency to look at the cones that you're just passing. If you're already at them and aren't about to run them over, they don't matter any more.
      Take it fairly easy on the first run and don't worry about the time at all. It's generally easier to add speed on successive runs than it is to dial it back (plus it's encouraging when you find out that your second run is several whole seconds faster than the first, you know there's still more to be had, and maybe even where to find it).
      One thing the car does that I'd like to understand is that it tends to push right when I get on it. It especially happens when I shift gears, as if the unloading of the rear tires causes something goofy. Pre-loaded springs might cause it.
      Roll steer? If there's enough oomph to torque the chassis over with the throttle, the rear axle is steering slightly; normally this steers the axle to the left and makes things feel like the car has decided to make a right turn all by itself.
      And have fun.
      Norm
      Gone but not forgotten dep't:
    2. #22
      Dec 2002
      Lost Wages, Nevada
      Katz Man... whats been shakin' ??
      Hey, did you hear... ??... Pahrump is going private ?? Like "Resort/racetrack" style private ??
    3. #23
      Maybe ... but to be clearer: the dart to the right happens as I lift the throttle for a gear change. My steering is ultra quick (Tony Woodward forbid me to talk on a cell phone while driving ... he said answering the phone would be the same as a lane change), so maybe it is just the reach for the gear shifter?
      Oh, and thanks for the a/x driving tips. I appreciate it.
      jp
      ​John Parsons
    4. #24
      Central CA USA
      Quote Originally Posted by TheMonkey
      i didn't see that anyone mentioned it above... how much to turn the wheels when measuring for caster, and the multiplier for the difference.
      if you turn the wheels 20* to the right, take your camber measurement, then 20* to the left, take your camber measurement. most likely, they will have opposite signs (one tipping in, one tipping out). so, if you have one measurement of 1.75* in, and the other is 1.25* out, then the difference is 3*. multiply that by 1.5 to find caster.
      i think 20* turns multiplied by 1.5 is normal. this gets you very close. some people use bigger turn angles with a smaller multiplier, or smaller turn angles with a bigger multiplier, but offhand, i'm not sure what angles/multipliers work. it is not a straight line relationship. it is math that i cannot do, so i have to take the numbers at face value.
      Toe in turn calculations and charts here:http://www.smartracing.net/alignment.htm
      Katz!
      Man, I've missed you around here!
      David
    5. #25
      Dec 2002
      Lost Wages, Nevada
      Where is your hand placement on the steering wheel when shifting ?? If your single hand is above 9-3... this could be your culprit.
      Driving ergonomics plays a factor is driving smooth and consistant... as does hand placement on the wheel, the shifter and its as important as foot work on the pedals. Looks like it might be time for a driving "Mechanics" course.
    6. #26
      Nov 2002
      state of confusion
      I think a pretty close formula for the multiplier is
      [Multiplier] = 0.5 ÷ sin(steer angle)
      where steer angle is the amount you steer the front tires each way (not the total).
      David - Thanks for the smartcamber link.
      John - Glad to help.
      Norm
    7. #27
      CA
      Dave, JP, Matt, Norm, and Tom,
      I’m still alive. Just stopping by to help JP out. I don’t really intend to come back here regularly. My interest has shifted. No more hotrods for me, and I’m interested more in developing myself as a driver than car setups.
      Besides the fact it’s more fun driving than working on cars, as I wrote in my previous post, my slow-working brain finally started to realize that having a theoretically-perfect chassis don’t mean a **** if you can’t drive well. Some of you already know I have been driving E30 BMWs these days. The cars are cheap and good platforms to learn how to drive, and don’t take much prep for track duties. Suspension kinematics are ****ty at best (McStrut/Semi-trailing arm), but the cars are pretty well-balanced even with factory springs and bars, and ergonomics is one of the best layouts I've seen on production cars for track driving (the only complaints are seats sit too high and clutch pedal a bit too high for left-foot braking). 32mpg helps tremendously with today’s outrageous gas price also.
      I've only done 12 track events so far at six different tracks (Streets of Willow, Big Willow, Laguna, Buttonwillow, Vegas outside course, and Pahrump). Still a lot to learn, but I’m already running a few seconds faster than I ever did in my Buick in an old 4-cylinder BMW that costs a fraction of what I've spent on Buick.
      These days, I'm more about laptime per dollar than building and cruising in a badass-looking muscle car.
      ...I'm really looking for confirmation that the car is built square and level, and that the thrust angles from the back wheels are reasonable...
      That’s understandable.
      ...I just want to be sure that I eliminate excuses when I get out there and lose to Mini Coopers on the autoX...
      It’s better to have as many excuses as possible, actually… But seriously, don't be so hard on yourself if you get beaten by Mini's, Miatas, CRXs, and the likes.
      ...One thing the car does that I'd like to understand is that it tends to push right when I get on it. It especially happens when I shift gears, as if the unloading of the rear tires causes something goofy...
      I’m thinking it’s a combination of stuff mentioned by you and others, compounded by the locking differential (I thought you went with Detroit locker). My experience driving locked vehicles is limited to my old rockcrawler and another 4x4, which I obviously never cared to check corner weight, axle steer geometry, etc. But I do recall them doing something similar to what you’re describing when axles transitioned from unlocked to locked or vice versa.
      How about just backing off the throttle with clutch still engaged? Would that still cause the car to move around? If not, try backing off the gas AND step on the clutch as if you’re going to shift, but keep both hands on the wheel and see what happens.
      I thought of roll steer as Norm did, which would have made sense if the car darts to right when you get on the throttle as I built in slight roll understeer. It seems to be the other way around, but it still could be a possibility. Try changing PHB height and see if that has any effect.
      ...My front bar is too big (according to your spreadsheet), because the swing arms ended up shorter to accommodate the radiator. I think it will push a bit...
      I wouldn’t worry about that for now. Once you get the alignment and corner-weighting done, I'd just try cone-dodging and/or track events as is. Only then, you’ll be able to make meaningful assessment of car’s handling nature. Goofing around on street won’t tell you anything.
      Just have fun driving and get to know the car well. Your preference of car's handling will change anyway as your driving skills progress. There's no sense spending time and money trying to dial in the car spot-on, knowing you'll have to mess with it later anyway. Me for example, I used to be very comfortable driving a slightly understeering car and I probably would have scared myself if I got in a neutral car. Now with the same understeering car, I get frustrated as hell.
      Speaking of corner balancing, be sure to disconnect the bar links. Once the weight is balanced, adjust the link length so there’s no preload with you (or simulated weight) behind the wheel.
      Dave
      I owe you and Mary a dinner. Not sure if I’ll be back to drive at Laguna anytime soon. Maybe when we see each other at Buttonwillow or something. Any interest in running Big Willow with SV in June/July? I’m dying to try Big Willow again as I think I can dip below 1:40 with better line and new suspension bits.
      Tom
      I read about SMMR on CC.com a while ago. I suppose membership feature and 22 days/month track access are very nice if you are one of wealthy people who can afford such luxury. Mortal track day participants and organizers seem to be concerned about those wealthy members barging in during track events.
      Like this past weekend, for example, there were two 911s, a flat nose and a Targa, running in my run group (advanced intermediate). The median lap time for the group was 3:25-ish and those two were running around 3:50~4:0x!! And they wouldn’t point people by, until they got their hands slapped by the event officials. My buddy Brian, who copied my idea and got himself an E30, was running 3:48 in the beginner group. I can totally see more of this happening.
      I have no problem with people with nice cars with not-too-impressive driving skills, so long as they’re honest about what they're capable of. Unfortunately it seems too many of them think they are entitled to be in the faster groups just because they have fast cars. Honestly I think everyone would have had more fun if those two stepped down to the beginner group. P-car drivers would have been able to concentrate more on driving instead constantly watching mirrors for overtaking cars, and we would have had more clear laps.
      The best I did was 3:28.2. I did that in the morning with some traffic. Unfortunately by the time I got used to the track, it was getting hot and I started to lose my tires and brakes. I’m a little disappointed with the time. I’ll be back in November event with better brakes and try to do 3:23-ish. You Vegas dudes should come out.
      EDIT: Just so my time doesn't look super slow, we ran on new 3.5-mile layout. Good drivers in fast cars (Z06, S2000, Elise, etc) run 3:00~3:10 range.
      The first step of becoming a better driver is to attend a track event, time yourself, and realize the fact you really suck.
      Signed,
      A driver who laps Big Willow at 1:42.6 in a 134hp BMW - and I am still considered mediocre.
    8. #28
      Newbury Park, CA
      To get a level pad in my garage I use a laser level and target the center of the wheel hubs. Working my way around the car I'll place plywood under each tire until all four are at the same level.
      Buying your own equipment is the way to go. After doing it a few times you'll be glad you invested in the tools.
    9. #29
      It's done. It took 4 hours, but the car is aligned and corner weighted.
      Numbers: 48% front, 52% back. (exactly as Katz predicted)
      Corners are 50/50.
      Total weight (less driver, 1/2 tank of fuel): 3305 lbs. Driver weight: too much (to coin a phrase). Loaded weight with driver: 3503. My race diet begins today.
      The car arrived with 1/4" toe out, -1.4* camber on the left side, and -0.8* camber on the right. Caster was 4* on both sides. I was pretty happy that the car came in level and pretty well set up considering my crude construction methods (tape measure, framing square, 48" construction level on a non-level floor)
      Katz designed the car for dual mode, and the UCA is bolted into the street setting now. The street setting has less camber gain and side scrub. We couldn't get more than -0.8* camber on the passenger side, so we put the driver's side there as well. 6 degrees caster. 1/8" toe out. Centered the wheel.
      We also set up the thrust angle using a tape measure, and the wheelbase was 1/8" longer on the right side, so we fixed that.
      The rear sway bar was left home in the garage, and we disconnected the front bar during the set up. The driver's side bar link had to be lengthened an 1/8" or so to connect back up.
      With those changes and no rear bar, the car drove straight, felt much more balanced, still a bit darty, and exhibited no tendency to turn right on gear shifts. I'll have to watch the rear bar to make sure it doesn't induce pre-load when I put it back in.
      All that for only $227! Carl, you're right: it seems the tools will pay for themselves pretty quickly!
      jp
      ​John Parsons
    10. #30
      The guy that did the set up is a driving instructor at Sebring. He's my new friend, and he'll be doing some co-pilot work with me. That will be fun.
      jp
      ​John Parsons
    11. #31
      California Bay Area
      Please post a video when you track it,I would love to see that car in action!
      65 Impala
      01 Z06
    12. #32
      CA
      My estimate of weight was a bit too optimistic. Carpet, insulation, A/C, big full-length exhaust pipes, etc, add up quite a bit. You may have to bump up spring rate a little WHEN you start pushing the car hard.
      I guess we’re paying the price of designing the whole thing via e-mail/fax/phone calls. You should have been able to get more than –2.0* camber easily. Moving the UCA mounts to lower holes should give you some more camber, but not by much. Try backing off the caster and see if that will let you have more camber next time you align the car. Making new UCA cross shafts (with some offset) is probably the easiest permanent solution.
      Did you use heim ends for rear bar links, or did you use poly bushings? If you have OE-like poly & tube end links, you need to trim the tube (or sleeve) to dial out preload. Converting them to heim joints is the best thing to do IMO, if possible.
      Good thing you have an instructor friend. He can probably help you establish a good baseline setup for your current driving ability. Be sure to go for a ride when he drives, whether in your car or his car.
      Signed,
    13. #33
      Oh, I can get more camber. A lot more. Remember, we put the UCA frame bracket on the inside of the frame rail. The design of the suspension places the UCA cross-shaft on the outside of the rail. I have 1.75 inches of spacer there. The problem is that I need a spacer about 1.5" thick so I can shim. It's an easy problem to solve ... it's just that I couldn't solve it there, 30 miles from my shop.
      As far as weight goes, I was hoping for something a few hundred pounds less. The car is dyna-matted on the floor, doors, and rear wheel wells. Fully carpeted, hidden stereo (with a sub), console, back seat. (no A/C though). I guess it was to be expected.
      My rear bar is OEM poly style, so trimming the sleeve is what I need to do. No big deal, but it will take careful setup of the car to get it level with the suspension loaded so I can figure that out.
      jp
      ​John Parsons
