    Page 1 of 3 1 2 3 LastLast
    Results 1 to 20 of 49
      Oct 2006
      AM max g chassis builds
      anybody got any more links to any max g chassis builds?
      we're seriously contemplating getting one for our 65 mustang build, and i was just wanting to see a few examples on how people are mounting the body to the chassis
      thanks ahead of time
      Feb 2006
      San Diego, CA
      I also would be interested in anyone else's experiences with these chassis! The AME G-Machine chassis and Schwartz Precision chassis are the only two unconventional chassis/suspension set-ups that I'm investigating/ruling out for my '67 Firebird Project (Project: Tomahawk in the Project Updates section).
      Thanks for sharing!
      '67 Pontiac Firebird 400 RA
      http://www.lateral-g.net/forums/showthread.php4?t=7693
      '97 Camaro
      '00 Yamaha R6
      '01 Aprilia RS-50
      '02 Yamaha R1
      Aug 2003
      Parson II Much Chevy II has one and it is Badd Ass. I also did a bolt in chassis in a 55 Chevy, Simply killer.
      Thanks Frank!
      My chassis is a Morrison all right, but is from before their Max-G set up. I cut the front and rear suspension out of the car and made my own ... if I had started with a Max-G I wouldn't have had to do that.
      If you want to see some photos of how my chassis and body go together, click on my sig.
      jp
      ​John Parsons
      Jan 2007
      cough* R&D for a badass full caged chassis with fiberglass body is in the works at g-machine cough*
      Bringing innovation into the industry one build at a time!
      Oct 2006
      Thanks Frank!
      jp
      i'm looking, do you have any specific pics?
      you are using body mounts right?
      or is the body welded to the chassis
      The body is welded to the chassis. Weld points are the rockers, firewall, trunk, and wheelwells. From the engine compartment back, there is sheetmetal welded to the frame continuously.
      jp
      ​John Parsons
      Fife, WA
      Quote Originally Posted by absolom
      Right now, Woody's Hot Rods is putting together a 69 Mustang with one of our MaxG chassis under it. The entire build is being covered in Super Rod magazine. Last month they did a step by step series on how they mounted the body and used most of the stock floor sheetmetal. It was a very cool install. If you can't find it on the news stands, let me know and I will send you a photocopy.
      Batesville, IN
      I've got to get over to Woody's to check out their projects. They are only about 5 miles from my house and I've never been to their shop.
      They are also doing a '65 Comet with a Max G under it. I'm not sure how far along it is though.
      I believe they are setting it up to be able to remove the body from the frame on both the Mustang and the Comet.
      Here is a link to their site - I think they have some pics posted
      http://www.woodyshotrodz.com/
      Later,
      Brandon
      Brandon Wiedeman
      1972 Suburban
      Wiedo's
      Oct 2006
      Quote Originally Posted by CraigMorrison
      awesome, i've been to their website and checked it out, i'll see if i can find a copy of super rod
      i talked to steve webb and he worked me up a quote, hopefully, we'll be ready to order it at the beginning of the summer
      Oct 2006
      jp
      why did you decide to weld the body and chassis together as opposed to using body mounts?
      I considered making the chassis "removable". But, in reality, is that really ever gonna happen? Do you really ever plan on removing the body? If so, why?
      The other thing to consider is that my car has a cage. How do you weld in a rollcage and still have the ability to remove the body? Also, I used the frame rails as a big "jig" to hold the body in place (relative to itself) as I rotated it around on a body rotator. I'm not sure I'd be willing to do that with a raw body.
      jp
      ​John Parsons
      Oct 2006
      jp
      i've kinda got the idea of doing a small cage in the 65 stang, and using the floor plates as some of the body mounts to the chassis, along with fastening it at the rocker panels and right below the firewall
      excellent project by the way, definitely some amazing work
      Thanks!
      Whatever you decide, give Kevin Kosir (ext. 222) at Morrison a call. He's been there and done that with just about everything. He can give you tech advice and guidance from a real world standpoint.
      jp
      ​John Parsons
      Auburn, WA
      jp
      That is a very true statement. We often get questions on wanting to make the frame removable, but you pretty much summed it up. If a person is going to go this far when building a car, what is the chance they'll want to tear it all apart? With this method, you get a rock-solid body structure.
      Matt Jones
      Mechanical Engineer
      Art Morrison Enterprises
      is it more of a detailing issue when bolting the frame in?
      Oct 2006
      Quote Originally Posted by silver69camaro
      did alloway make his 67 bolt on or did he weld it?
      I think many people approach this with an initial thought of bolting onthe body because they see those cool street rod chassis in magazines. You know: full rolling chassis complete with drivetrain. Beautifully finished, and looks like you could practically drive it.
      You can do something like with a street rod, because the bodies bolt on top of the frame. For us muscle car guys, that doesn't work so well, because the car would sit too high. To get this to work, you need to channel the body over the frame (the more, the better!), and that makes it difficult to make the body bolt on.
      If I had a customer that required a bolt on body, I'd make it like this:
      1. Get a chassis that is 1/8" narrower than the rocker panels on the car I'm building.
      2. Create a floor that bolts on to the chassis and is suitably reinforced. It is important to leave a weld edge for welding to the rocker panels.
      3. Cut the floor out of the body from rocker to rocker.
      4. Position the body on the chassis/floor combination and weld the floor to the rocker panels of the body.
      Now you can unbolt the body from the chassis and do whatever you want to with it off the chassis. You'll need lot's of hands or some sort of crane to move the body around, and you'll also want to be sure and add some reinforcement so that the body doesn't flop around when the floor is cut out of it.
      jp
      ​John Parsons
      Auburn, WA
      Welded with 10 gauge floors, if I'm not mistaken.
      Matt Jones
      Mechanical Engineer
      wow that is light, the floor must weigh a couple hundred lbs minimum.
      Rodger
