      Fontana, CA
      Can't tighten LBJs enough
      So I was checking everything and noticed my LBJ nuts were loose. I tried to tighten them and got to the point where I ran out of Thread on the stud. My Factory control arms with PST brand LBJs did not have this issue. The spindles are aftermarket pieces which have worked fine for 6+ years. The GW arms have Moog LBJs, wondering if this has anything to do with it.
      2 questions:
      1. Is it OK to use hardened steel washers between the castle nut and spindle?
      2. What is the bolt size of the LBJ stud?
      I have a call in to Global West but wanted a few more opinions.
      Thanks.
      Nick R.
      Hardened steel washers will work fine. Just make sure they don't bind on the stud. I had to make an aluminum spacer for mine for the exact same problem. I check 'em weekly and they are holding up perfectly so far.
      jp
      ​John Parsons
      Is it possible that you got control arms with the wrong LBJ? Sounds like the shank is a little small and its going all the way through the spindle. Remember ball joints are tapered so they need to fully seat.
      Andrew makes a good point. Ask about the taper and make sure the LBJ and steering arm/spindle are the same.
      jp
      ​John Parsons
      Fontana, CA
      Tech @ GW says he's never heard of this issue before but cleared the spacer and says they actually provide them with the Mustang lower arms as the LBJ they use is not a ford piece and is longer than necessary. I asked about the taper and he says there is only 1 LBJ they use that will fit the control arm. I will verify anyway.
      Thanks for the help guys.
      Nick R.
      Los Angeles
      Quote Originally Posted by 6'9"Witha69
      Tech @ GW says...
      Enough said.
