Thread: one-wire alternator question
04-15-2007 #1
OK, having a brain cramp. I have a polished aluminum one-wire alternator that's mounted by aluminum clear coated March brackets to aluminum heads. No connections to anything steel or iron. In that case, do I need to run a ground wire from the alternator to a ground?
Bob
Mooresville, NC
'66 Chevelle SS (461, T-56)
https://www.pro-touring.com/forum/vb...?do=view&g=274
04-15-2007 #2
- Feb 2007
- memphis, tn.
- 14
i would say definately yes. you can never have too many grounds. i had an factory style alternator maounted to a powdercoated serpentine set-up w/ aluminum heads. my alternator worked for a couple of days then nothing. it baffled me for a while but it all turned out to be a bad ground due to the powder coating. i ran a ground wire from the back of the alternator to one of my motor mount bolts, been problem free ever since.
04-16-2007 #3Aluminum will conduct electricity just as well as steel, it's just not magnetic. In fact, back in the 'good old days', many houses used aluminum wiring. Until a short circuit caused the aluminum to melt............and caused a fire.
04-18-2007 #4
New to Pro-Touring
- Mar 2007
- 25
You do not need a ground bro! Bun is right on! and the alt. contains enough metal to ground itself anyway.
04-19-2007 #5
