    Thread: wilwood master
      NYC
      wilwood master
      i was told that the wilwood master that the lines for the front brakes go to the back inlet of the master is this true and can i use the stock prop valve instead of the adjustable one from wilwood forgot to say that the prop valve is for disk/disk thanks mike
      Aug 2003
      The Wilwwod Master is front / front, rear / rear. As for the Prop valve, that depends on what prop valve and what brakes you have?
      NYC
      thanks frank for the reply i have the 4 piston wilwood the prop valve i have is the one that looks like stock but its for disc im not to thrill for the adjustable prop valve i want more of a stock look thanks mike
      Aug 2003
      All you do it try it and if the bias is off, you can hide the Wilwood Prop valve by the differential at the hose that goes to the rear
      NYC
      thanks frank good idea if it dose not work do i leave the stock prop and put the willwood in the back
