      Morehead City, NC
      T56 install help
      I am using an LS2/T-56 from an 05 GTO in my El Camino. I cannot use the clutch master and slave from the GTO. I am using a GM 12570277 F body master and need the matching Fbody slave. Anyone know the GM part number for the slave. I have searched the PT achieves as well as LS1techs and find part numbers, but not sure which would be correct.
      Mike
      Huntington Beach, CA
      Don't have the answer for you. Just curios that the 05 GTO setup used a slave cylinder instead of hydrolic throwout?
      Morehead City, NC
      It's an internal slave versus external slave. Obviously it's a hyd. throwout brg. Gm still lists it as a slave. I found the part number last night. GM # 15046288, slave cylinder w/release brg. F-Body 98-02.
      Mike
