Results 1 to 18 of 18
Thread: Brake experts comparisons please
04-08-2007 #1
OK I've tried the search and it really doesn't give me much help .If we could have a comparision in one spot it would be great.
1)Front Calipers- piston size & mountings spacing comparing LS1,C4,C5,C6,04-06 GTO.
2)Rear calipers -piston size,mountings spacing and with integral E brake on caliper or if mini drum required -LT1,LS1,C4,C5,C6,GTO
3) rotors- diameter and thickness AND offset on front and rear. I thought I had read somewhere the C4 are closer to the 1" thickness earlier discs are whereas C5/6 are 1.25.
I've got some 79-81 TA rear setups I can measure.
04-08-2007 #2
- Dec 2006
- Los Angeles
- 334
Skip, I think I read that there were some rotors that are 1.1" thick.
I currently have my rear apart and am putting in the LS1's, but it looks like I will have to fab something for the e-brake bracket, so I will probably leave that part off for now.
04-08-2007 #3FYI
1LE rotor out of the GM box 11 13/16 diameter, 1.025 thick, wheel to disc offset 1 13/16"
79-81 TA rear disc 11 1/8 diamter, 0.982 thick(new non GM),1 3/16 offset
04 GTO used rotor hat type front 11 9/16, 1.082 thick, 2 1/16 offset
04 GTO rear 11 1/4 diameter 0.637 solid disc, 2 1/2offset
04 GTO cliper brakets both have 3" mounting centers. Front caliper 8" center, rear 5 11/16 center
My 78 8" snowflakes are 12 7/8 diameter at the hub level and 14 1/4 at the rotor level with the 1LE. Even has an extra 1/2 " diameter clearance with the GTO calipers on the 1LE rotor.
A 89 GTA mesh is 13 7/8 at the hub and 15 1/2 the outer area. Rear wheel has a 5 5/16 back space.
04-08-2007 #4Is the measurement for the 1LE rotor for front or rear?
04-08-2007 #5Front rotor-new GM, I didn't think the 3rd gen 1LEs used a rear special rotor.
04-09-2007 #6Thanks. That's what I figured but wanted to makle sure. Based on your measurements, the 1 LE is not that much bigger than the stock 2nd gen. Thicker and will probably take more heat but not much bigger. By my calculations, it is a little .ess than 3/8 bigger in radius.
I have been contemplating the 1 LE conversion for my TA, but since I am 99 % street driving only, I don't know if it is worth it.
Thanks for the numbers.
I think you are headed in the right direction with the post. I would like to see it become "sticky" as it has the potential to be a very good resource.
04-11-2007 #7c'mon jeremy, it is the easiest, cheapest bang for the buck. I have ben using them for many years. i also have Wilwood GM iii aluminum calipers and Hawk HPS pads, works on the track really well. Not an expensive set up either
Keith
04-12-2007 #8
