    Results 1 to 10 of 10
      Nov 2004
      Sweden
      Country Flag: Sweden
      Rag joint swap .
      Hi!
      I read a post about changing the original rag joint to a universal joint , when You lower the body over the subframe.
      What do I need to make it fit ?
      Is there a universal joint that will fit the original steering column ?
      Found this thread.
      " https://www.pro-touring.com/forum/sh...hlight=coupler "
      What is a DD shaft?
      Anyone got pictures ?
      Partnumbers ?
      "Osdmike"
      Aug 2003
      We can set you up with a conversion joint. Manual or Power steering? BTW, a double D shaft is the intermeidiate shaft on a front steer car. You do not have one in your Camaro.
      Nov 2004
      Sweden
      I have original Power steering.
      Do I have to modify the steering column at all,...or is it bolt on ?
      Pics?
      Price?
      Osdmike
      Eastern Virginia
      I would like one too for an 86 Monte with power steering.
      Scot
      86 Monte SS
      Burnaby, BC, Canada
      Just did this on my car, for different reasons (I needed header clearance) try www.borgeson.com or www.flamingriver.com you'll have to measure for the correct size. Mine ended up being 1"-48 spline (stock tilt column) and 13/16" - 36 spline (steering box end)
      Here's a pic:
      1969 CAMARO RS
      Project pics of my '69
      Lateral-G Feature Page
      Nov 2004
      Sweden
      Thanks for the picture ! That explains a lot.
      There is no splined shaft coming out at the bottom ,where the rag joint is attached.(see pic.)
      I dont know if this is the original column.
      I also looked at two other Camaros (-68 and-69)
      The -69 column looked like "Rybar´s" .
      The -68 had a big hex nut , where the r-joint is attached.
      So here we have three different steering columns for 1st. gen. Camaro.
      I guess I have to find an other steering column , with a splined shaft.
      That will solve My problem.
      "Osdmike"
      Burnaby, BC, Canada
      Mike, e-mail that pic to the tech guys at Borgeson or Flaming River, they should know what you have there.
      1969 CAMARO RS
      Nov 2004
      Sweden
      OK ! Thanks.
      "Osdmike"
      Nov 2004
      Sweden
      Universal Joint.
      Yeah!
      Got a Nova -77 tilt steering column !
      Flaming River 1"-48 / 13/16"-36 spline Universal Joint.
      Works great !
      "Osdmike"
      Burnaby, BC, Canada
      Great news, it was a big pain for me to figure out the correct size, I'm really glad I could help you out.
      1969 CAMARO RS
