    Results 1 to 11 of 11
      Connecticut
      2001 Chevy Camaro Trouble
      hello I have a 2001 6cyl 5 speed chevy camaro. my troubles are when i change gears and hit the gas again the car will buck. it is really bad in 5th gear. it seams like it could be bad gas but i am not sure any other suggestions????.thanks
      CHICAGO SUBURBS
      Check the trans mount. Your discription is pretty vague.
      Connecticut
      i will try to describe it a little bit better. it seems when i am going at a steady pace it runs fine but once i hit the gas to pass or to go up a hill it starts to shake and almost like pop. hope that might describe it better.
      Jun 2002
      Long Island, NY
      I doubt it's the trans mount...if it was loose, you'd feel it banging against the rear floorboards.
      Nov 2000
      O-town
      Lean miss from low fuel pressure??????????
      How many miles??
      Connecticut
      105,000 miles how do i fix it???
      ghent new york
      you might want to check fuel filter
      Connecticut
      where is the fuel filter on these cars?? i hope it is not in the tank.
      Jun 2002
      Long Island, NY
      I'm pretty sure it's right past the drivers side rocker, towards the back of the door. It's been a while since I've crawled under my car though, so I may be confusing another car. It's definitely not in the tank, though.
      Southern Indiana
      OK for one if you have anyone you can get to check the fuel preasure have them hook up fuel preasure guage , and un hook the fuel preasure rgulator and wing the throttle and if it drop more than 1.5 psi your pump/filter is not up to the task.
      Also look at your ignition, if it has a distributor with a seperate coil look on the sides and see if you have a whiteish "burn mark on the sides near the laminated iron core,,, GM has a problem with them loosing voltage through the sides as they get old.
      Verifiy its not lacking in regualr tuneup maintenace (and if you haveanything other than AC Delco plugs in it good luck) look and see if its black in center of rotor if it has distributor.
      Been so long since I worked on one I forget what type of ign setup it has.
      Lee
      Connecticut
      thanks guys i will get looking itno all this stuff this weekend. i will let you know what i find.
