    Page 2 of 2 FirstFirst 1 2
    Results 21 to 23 of 23
      I think I may just play it safe and go with the 285/40/18.
      As much as I'd like to have a 315 out back, if it rubbed
      then I'd have to make room and then I'd want to run
      a 345 out back... $$$... where does it end?
      SMSgt Ty Ingle, USAF
      "CF71" - Freedom Bird
      Ontario, Canada
      Quote Originally Posted by 71FirebirdLS1
      ........the drive-shaft tunnel had to be cut and moved over to fit the panhard bar and the rearend will be held in by the underslung bars from the frame.......
      Aaron,
      Looks like you have quite the project in the works. I've always thought that the '70 to '72s were some of the nicest 'Birds built. If I read correctly, it sounds like you're using the torque arm suspension from the '01 TA. Am I right? If so, you will have to post some (nooo.... a lot of) pictures in the suspension forum. The Gen 3 & 4 guys seem to be able to make this suspension system work well. I'd be interested in what you have to do to get it stuffed into an earlier model.
      Ken
      My other car is a Vega.
      stanwood, wa
      I am running 17x11's in the back with 315's and have no rubbing problems and with a little massaging(rolling the fender and maybe mobing the upper shock mount in) I am convinced that I can fit a 335.
