    Results 1 to 12 of 12
      jsconiers 68 fire-bird progress
      Starting a new official thread to show my progress. These are pictures of my 68 firebird convertible that the previous owner turned into a camaro. Plans are as follows:
      Interior and paint are still in the design phase. Running a stock interior but thinking of using convertible sebring seats. Paint scheme would either be Black, Blue or Red. Not quite sure yet. All three colors have been done millions of times. Dark Blue with black interior would be my pick but I haven't made up my mind yet. I saw a really nice black on black that I liked as well.
      T56 and LS1
      Modified BRP sub frame
      ATS T56 Hydrolics
      SW headers
      Fast 90MM Intake and throttle body
      ls1 disc brakes all the way around
      99 mustang hydro-boost conversion
      tubular upper and lower control arms
      qa1 springs
      BRP R&P
      Rear Quadra link or g-bar setup
      12-bolt rear end
      Undecided on wheels but 18" Torq thrust 2s are in the lead
      Digital gauges
      Power window kit
      Hidden radio and alarm
      First three pics are kind of old....I've gotten rid of the front end.....
      And a few more:
      CT
      Is the LS resting in there? Does the subframe have to modified?
      John
      The LS1 is resting in there and my sub-frame was modified. You can install without modifying your sub-frame but will have to notch your f-body oil pan, or buy one that is notched to clear steering. I have R&P steering so I didn't have to do that. Sub-frame kit was from BRP hot rods.
      Atlanta GA
      wow... you gonna keep it a camaro?.. or back to firebird?
      back to a firebird
      Quote Originally Posted by Venomous Type
      Atlanta GA
      To Do List
      This is my To do List. Will Probably edit many times:
      Mechanical:
      Finish Installing LS1 accessories
      Mount PCM and wire engine up
      Install T56 clutch master and pedal assembly
      Install interior shifter for T56
      Purchase and install FI gas tank and run gas lines
      Re-flash PCM
      Install 99 mustang Hydro-boost master and booster (got the idea from here http://www.geocities.com/casanoc/)
      Install LS1 brakes on rear 10 bolt using bracket kit
      Run all brake lines
      Purchase and Install 4-link (Either DSE or Chris Alston G-Bar)
      Shorten and install LS1 aluminum drive shaft
      Install 4th gen radiator and fan assembly
      Figure and purchase wheels / tires
      Install correct flaming river mounting bracket and horn adapter on steering column
      Purchase and install new steering wheel
      Purchase and install new front light harness
      Purchase and install Vintage air A/C system
      Purchase and install new battery
      Purchase and install headers, x pipe and dual exhaust
      Rebuild 12 bolt for later install
      Body:
      Install New convertible top
      Purchase and Replace passenger and driver rear quarter
      Install DSE Mini-tub kit
      Purchase and install deck lid
      Purchase and install DSE sub frame connectors
      Purchase and install complete front assembly (hood, inner and outer fenders,etc, have nose assembly)
      Purchase and install tail panel
      Purchaser install chrome trim and window lace material
      Install new antenna
      Install passenger and driver mirrors
      Purchase and install emblems
      Install insulation
      Install carpet
      Align Body panels
      Prime Car
      Other:
      Purchase and Install Power window kit
      Alarm
      Digital dash
      It's been a long time since I updated on the build. Well I've decided I need some help. I contacted a local shop for help. They've done some really cool projects and I was very impressed with their work. I stripped the car of it's interior and all of the exterior parts. The only thing left on the inside is the door panels and dash. The door panels will be coming out tomorrow.
      I decided to make some changes in the build of the car as it will not be done by July as I first thought. In short I'm going to build the car so there will be no regrets later on. I sold my 12 bolt, rear disc kit and T56 setup. I was going with the g-bar but I contacted Detroit speed and am now sold on their quadra link kit. while I'm at it I'll be purchasing their mini tub kit, ls1 gas tank, sub frame connector and firewall filler panel. I think I'm going to go with their 9" as well because it comes setup with the brackets. I'm also thinking about the Budnik Fontana 18x10 but I'm not quite sold. I'm going to settle on my wheels before ordering as the rear end is setup for the back space of the wheels. In any event I know I'm running a 295 tire.
      I picked up a nose assembly and front valence panel from Florida. I just finished ordering a bunch of sheet metal (quarters, tail panel, outer wheel houses, trunk drop off, fender extensions, core support, battery tray kit, etc) from a local vendor. Got everything except the hood, fenders, bolt kit and a few other small front end parts.
      I also ordered a Ford Motor sports disc brake kit for the 9" and purchased a 4L60E and 4l80E. The 4l60E will be installed immediately. The 4L80E will be installed after a rebuild , level 10 parts, transgo shift kit and other goodies.
      Been spending a lot of money. One good thing is I found a local place that has LQ4's pretty cheep. Thinking of seeing if any one wants one on the board.
      Atlanta GA
      those wheels would look SICK on it done.. i just realized what they would go on.
      the ones you have or the fontanas....
