    Results 21 to 21 of 21
      Scottsdale AZ
      Fuel presssure drop
      I have a 1969 Camaro with all new tank, lines, motor, pump, and carb.
      The car ran fine (100 miles) until recently.
      Now it will start fine with 7 psi fuel pressure. After a 10 minute drive the car will start to die and have fuel pressure between 0-3 psi.
      I tried swapping pumps and it still does it. The pump I swapped was used and I assumed it was good, but it may not be.
      I removed the line from the tank to pump and notices that fuel trickled out (not poured).
      I removed the tank to ensure that the "sock" was clean and there were no obstructions. There were non as everything is new.
      I put my finger over the inlet hose from the pump. Should there be suction? There was none.
      Any suggestions?
