      San Francisco
      Engine Oil Leaking from Breather?
      I've recently put in a new fastburn385 crate motor in. I think it has about 1k miles on it.
      I'm leaking oil on the driver's side from the top. The oil accumulates on the driver's side intake grooves and form little puddles. The brake booster has a light dirt/oil coat, and the breather is soaked in oil.
      I'm using the factory valve covers that came with the engine. They look like LT1 style centerbolt, with baffles where the breather sticks in.
      The passenger side is fine, pcv and oil cap do not leak. I'm considering it might be a freeway problem? I sometimes cruise at 4,000 +- RPM for long durations on 1 hour trips from SF to SC.
      Any ideas? Thanks!
      Oil press seems to be alright. The sheet says it should be @ 40 PSI from 1500-2000 RPM, but in reality it looks like it's at 40 PSI in idle (800-1k RPM) - can't be too accurate with short sweep auto meters though.
      1967 Chevrolet Camaro 350/350
      1962 Chevrolet Chevy II 400 194/PG
      Jan 2007
      Fort Worth, TX
      Do you think it might be a little blow-by from the rings not being fully seated since it is a new motor? Perhaps it will go away once it is broken in more?
      Mustang Status
      Current Status ChemoTherapy for the Cancer (Rust)...
      All My Mustang Progess Pics
      San Francisco
      oh, heh yeah if that's just what happens - i never had a new motor before - thanks! i was real worried there.
      Central CA USA
      Is the left side breather in a rear hole or front hole on the valve cover?
      Generally, the rear hole is to be avoided on either side. Lots of oil collects in the valve covers at higher rpm's. It tends to be worse at the rear of the engine.
      David
      San Francisco
      both holes for pcv and breather are on the rear part of the valve covers. i've wanted to get new valve covers, simple with no chrome, and i saw a pair with a crossover tube on the front, with two provisions for breathers, but i don't know if that'd be okay for the street?
      it also has no pcv hole, but that shouldnt be too hard to create, right?
      this car is purely a daily driver. someday race, but not there yet.
      Nov 2000
      O-town
      I had a problem with a SBC in the 80's when you get on it it fogged like a crop duster, went with a factory style breather and PVC valve instant fix didn't leak or burn oil. try those and see what happens,
      San Francisco
      what is a factory style breather? i'm using a K&N breather, and i think a factory pcv valve.
      Nov 2000
      O-town
      Usually a tube that that would run from the valve cover to the aircleaner,
