    Thread: T-56 To BBC
      T-56 To BBC
      You guys here seem to know a lot about swapping the t-56
      transmissions to old school motors so hopefully someone will be able
      help.
      My car: 99 Trans Am Ls1 T56.
      Motor to go into Car: Blown 427 Big Block
      What is the best way to mate the stock trans. to the BBC while
      utilizing the SFI approved bellhousing i already have for the motor?
      Thanks.
      Walla Walla, WA
      Mike Kelcy - '68 Camaro with some stuff done to it.
      Petersham ,ma
      mcleod adapter plate and pilot bushing wil allow you to use all your bbc bell/clutch/flywheel, but then you will need to rig up the clutch linkage, i belive t56.com has through out bearing that you could adapt to the newer f body. good luck
      La La Land, CA
      If you are keeping the LSX style T56 and hydraulic setup you already have you will only need a McLeod modular bellhousing- 8710-10 to adapt it to the BBC.
      Tyler
      so if i go with the mcleod adapter plate and bushing, i won't be able to use the stock 99 trans am hydraulics????
      La La Land, CA
      That is correct. The adapter plate is typically to adapt cars with a 4speed and mechanical clutch linkage to switch to a T56 from an LSX based car. you already have the factory hydraulic system, so a swap to an 8710-10 will make it bolt to a BBC/SBC and retain the SFI rating, and hydraulic assembly.
      Tyler
