    Thread: Rookie DIYer
      Rookie DIYer
      I'm looking to convert my mustang from drums to disc's. I've never done it before and I'm wondering if anyone can give me a clue if this is something relatively easy to do with the kits on the market? Any special tools I am going to need? Trying to decide if this should go to a pro.
      Are you wanting to go with a stock type of system or upgrade to a '94-'04 Cobra 13" PBR caliper system?
      We have the brackets needed to do the PBR system. They use your drum spindles and hubs. No cutting is nessary and its a bolt on.
      Joe
      Wouldn't mind upgrading when I do it. Do you have a site I can see them on? Thanks.
      I sent you a pm.
      Aug 2003
      You can do a Wilwood kit with basic tools. The only "specialty toll required in a saftey wire plier, which can be bought at auto parts or online for $30 or so.
      Here are the instructions for your front kit and rear kit.
      http://www.wilwood.com/PDF/ds505.pdf
      http://www.wilwood.com/PDF/ds426.pdf
      NOTE: the rear kit may be a different part number, but it is basically the same assembly instructions.
