Thread: Help please!!
03-24-2007 #1
Help please!!
We have alot of smart and talented people on this forum unfortunately for me i am not one of them. I am in the process of switching from the drag look to the pro-touring look on my 71 nova. So i first started by changing the wheels and tires. I custom order a set of American racing cl205 17x8 rear with 4.75 bs and 17x7 front with 4 in bs all was good car road great but the 4 wheel drum brakes looked like crap and the car sat like a 3/4 ton. So i order a c5 brake kit from touring classics and put qa1 coil overs on the from and let the air out of the sky jacker shocks to lower the rear. With the new brakes it pushes out the track width a little so clearances are tight. Well the brakes are stopping the car but there is a small squeak sounds like a brake squeak and sounds like the rear passenger. so i re shim the caliper and still squeak re shim again and again and again. So today i pull off the wheel and roll under the fender and i find a nice clean spot on my outer fender where my tire has been rubbing bingo my squeek. the tire is barely rubbing because in right hand turns it goes away. So my question is how yall recomend correcting the problem new offset wheels, smaller tires? new suspension and try to true up the rear end (there is more clearence on the driver side), or do i break out the BFH and beat the snot out of it? Thanks guys all help will be greatly appreciated. I can provide specs and pics if needed.
Thanks again,
Shaun
Shaun McCarthy
68 camaro
