    Results 1 to 11 of 11
      Calgary, Alberta, Canada
      GTA Wheels - what is the offset?
      I've lined up a set of 16" GTA wheels for $150 CDN - they're not pretty (yet), but seem to be straight. I know that, ideally, you'd use 4 fronts on a 2nd gen F-body (fronts are zero offset) but the rears have a small offset.
      Is it negative or positive, and how much is it? And more to the point, can it be made equivalent to a zero offset by using a spacer? Or is that going the wrong way?
      Has anyone used a set of these on a 2nd Gen successfully despite the offset? Any problems?
      Steve
      1978 WS6-W72 4-speed Trans Am: Fire-Am Restification Project
      VSE front and rear sway bars, solid spherical control arm and spring eye bushings, front springs trimmed 1/2 coil, VSE aluminum oil pan and baffle; Pro-Touring F-Body solid aluminum subframe bushings, 1980 WS6 rear disk brake system, 12" 1LE front disk brakes, Alston cowl-to-subframe Y-braces and subframe connectors, Moser axles, Hooker chrome roll bar, Corbeau GT-8 seats.
      2000 WS6 Trans Am M6
      Rolla, MO
      I've run the 1986 ws6 16 x 8 wheels on my 2nd gen in the past. What worked for me was running the rears on the front and the fronts on the rear. No problems on either end and I thought the deeper dish of the fronts looked better on the rear as well.
      A 1/4 inch spacer on the front will push the wheel out a bit, but not as much as the rear. As I remember the gta offset is 16 mm which works out to .63 inches.
      Michigan
      use a one inch spacer in the rear
      1979 W72 Trans Am- original for now
      1996 Z28 A4- stock with an sts rear mount
      North Jersey
      I agree with Jeremy; I think the shallower lip looks better on the front. Swap the "front" rims to the back, and the "rear" rims on the front. Should work out OK.
      Steve Ragusa - North Jersey
      2006 Infiniti G35x
      St. Augustine, FL
      If anyone is looking for a set for sale. I have a set in gold. I was going to put them on my Nova but never got around to it.
      Andrew Petty
      Michigan
      I had them "reversed" on mine for awhile whiched looked ok , but if I remember correctly I was still touching the parking brake lever in the rear which needed a 5/16 spacer. The way I have them now fits the wheel the best, reversed the fronts were under the car to much, this way they are perfectly even.
      Linden Hill, NY
      reverse them and put a small spacer in the front.
      Andrew, how much are you asking?
      Well, I let this set go. They were rougher than I figured.
      Steve
      Raleigh, NC
      Does the same info hold true for a 1st Gen Bird, '69 to be exact?
      '69 Pontiac Firebird
      Orange and ugly, but getting there...
      Nov 2004
      Dallas Texas
      16 iroc wheels
      I had 4 rear iroc wheels on a 70 1/2 r/s back in 87-88 that fit fine but i had to use 1/8" spacers on the front - it had 255/50/16 eagles on it - and it looked cool - -early pro tour restomod?
      Rich
      69 Trans Am "TireBird"
      M6 / LS6 minitubbed DSE Sub
      C5 frt LS1 rear disc brakes
      https://www.pro-touring.com/forum/showthread.php?t=14992
      69 R/S Z28 302
      15 Camaro ZL1
      90 Formula next project
