      Jun 2005
      How to pick a tire
      I'm looking for some general help. I'm picking new tires for my stock wheels.
      What's going to give the best performance and wear properly?
      Is it better to fit the same tire on all 4 rims (the rims are the same size)?
      Is it ok to have bigger tires in back?
      Should the front tires be the same diameter as the rear?
      I know if you have a posi unit, you want to have the same diameter spare as your rear tires, so you don't burn up your posi.
      Mathius
      Jun 2002
      Long Island, NY
      Just my opinion, but---
      Quote Originally Posted by Mathius
      This would allow you to rotate all four tires, and possibly gain some extra mileage out of them. That's probably the main benefit to running the same size at all four corners.
      As long as they are still within the limits of the recommended width for that size wheel.
      Not necessarily. Most cars run a slightly taller tire in the rear. For example, on my '01 SS my front tires are 25.7" and the rears are 26.1".
      Houston, Tx
      Quote Originally Posted by Ralph LoGrasso
      Did you buy your SS new? I am pretty sure from the factory they came with 275/40/17's all the way around
      Jun 2005
      How close does your diameter have to be on your spare to prevent damage to your posi unit?
      I have a 155/70/17 donut off a corvette. I'm not sure on the rim size. (maybe someone can help me out?)
      I was going to use this with my '76 Malibu, hoping that if I go big brakes later, it'll clear and I'll have a bit bigger diameter for running bigger tires.
      Right now I'm still running the stock 15" rims. I was thinking 255/60/15's in the back.
      I'm willing to pay for a different size tire for the donut, but I don't know what size will fit, or how close I need to be.
      Maybe it's silly to try to plan my tire size around my spare donut, but I like to look ahead instead of doing things twice, and using a corvette donut will take up less space in my trunk.
      Thanks again in advance. I want to get this all figured out so I can get some new tires on this thing. The ones on it now are damn near bald.
      Mathius
      Jun 2002
      Long Island, NY
      Quote Originally Posted by Taylor1969
      I bought the car used, but I swaped out the factory wheels and tires for some 18x9/18x10 ROH RT's and some 275/35/18 / 295/35/18 Kumho Ecsta MX.
      Jun 2002
      Long Island, NY
      I'm really not sure, sorry.
      17"?
      Good plan.
      I'm not sure, either.
      I don't think it's silly to plan at all. Big brakes make spare tires a big problem for performance and pro-touring cars alike. I'm not sure about regular C5s, but C5 Z06s come with tire repair kits, and no spare.
      Jun 2005
      17"?
      Yes, I forget which years for sure, but I think it's something like 82-97 Corvette's had an optional 17" spare donut. I may have the years wrong.
      It's a trick I picked up in an old Car Craft I think. Supposed to let you run bigger brakes and prevent damage to your posi unit, and of course has a 5X 4.75" pattern like most of GM's glory day muscle cars.
      Unfortunately I don't know the width of the rim, so I'm not sure how wide I can safely go with a tire. I'm not trying to go wide, as I said it's supposed to be space saving, but I am trying to at least match the diameter as closely as possible for whatever rear tires I run so that if I run a posi unit, I won't damage it.
      Mathius
